> air/fuel gauge???
post Mar 15, 2007 - 10:24 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
Hey,
I want to monitor my air/fuel reading. Im working on doing lagos led knock monitor upgrade. What kind or brand gauge should I get. I dont have any aftermarket monitoring devices or upgrades. Im running the 91 3sgte. Thanks
post Mar 16, 2007 - 12:08 AM
6gsillyca
Joined Jan 13, '06
From UnderTheGround403
Get a wideband to go with it. Otherwise its just a fancy light show...
post Mar 16, 2007 - 12:48 AM
i have the aem uego wideband. its cheap and simple to use.
post Mar 16, 2007 - 1:34 AM
6gsillyca
Joined Jan 13, '06
Thats the one I was looking at getting, when i get around to a af gauge...
post Mar 16, 2007 - 5:21 AM
toyotacrazy
Joined Mar 4, '06
From Ohio
QUOTE(lagos @ Mar 16, 2007 - 12:48 AM) [snapback]536776[/snapback]
What should I expect to spend on a aem uego wideband a/f meter? I searched ebay and found them for $250-350. Could I just use my o2 sensor signal instead of getting meters with the bosch sensor included? Thanks
post Mar 16, 2007 - 8:55 AM
QUOTE(toyotacrazy @ Mar 16, 2007 - 6:21 AM) [snapback]536806[/snapback]
no you cant use your old o2 sensor. the gauges the use the stock o2 sensor are pretty much useless for air to fuel ratio monitoring. all they can tell you is if the car is stoich or not stoich, witch wont do you any good. a wideband comes with its own o2 sensor that can read you exact air to fuel ratio.
there is a big difference between an a/f gauge and a wideband.
post Mar 16, 2007 - 10:09 AM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
also have the uego. haven't run the engine yet so i cant tell you if i like it or not. but there pretty cheap on ebay, considering you get the gauge and sensor and its all plug and play.
post Mar 16, 2007 - 11:32 AM
yungazzdriver
Joined Feb 15, '05
From Frederick, Maryland
yes the uego aem widebands are nice but if you really want to monitor the air fuel get the wego wideband 2 with data logging, i paid 300 for the numeric lcd gauge, the o2 sensor, bung, plug computer cable, and all necessary hardware and wires nicec for the money, but i plan on getting this car tuned so maybe itll help you out later!
post Mar 17, 2007 - 10:45 AM
Celiracer18
Joined Aug 23, '05
From Princeton, Minnesota
Im using the Innovate Motorsports LC-1 Wideband and the XD-16 gauge.
Standalone Gauge Kit ($399)
They also have just a regular digital gauge
DB-Blue or DB-Red Gauge Kit ($289)
-Brian
Lo-Fi Version Time is now: June 25th, 2026 - 3:04 AM
