> Amp...
post Apr 1, 2007 - 7:46 PM
xpokeme
Joined Jan 18, '06
okay im getting frustrated wit this amplifier. i don't know whats wrong wit it, it keeps going to protect. once i turn on the headunit the amp turns to red for a second and then turns off... y?? i also switched ground.. any ideas?...where do you guyz place your negative ground? please help
post Apr 1, 2007 - 8:06 PM
djestylez401
Joined Nov 8, '06
QUOTE(xpokeme @ Apr 1, 2007 - 7:46 PM) [snapback]542110[/snapback]
where in the your car is the amp located?
This post has been edited by djestylez401: Apr 1, 2007 - 8:08 PM
"breakin necks since 1994"
94 Toyota Celica ST - Project Car
91 Acura Integra LS/VTEC SWAP- SOLD
90 Honda Civic Hatch DX LS SWAP- The Racing Whip
post Apr 1, 2007 - 8:47 PM
xpokeme
Joined Jan 18, '06
QUOTE(djestylez401 @ Apr 1, 2007 - 8:06 PM) [snapback]542119[/snapback]
my amp is in the trunk wit the 12 inch sub...
post Apr 1, 2007 - 8:57 PM
netrata
Joined Feb 16, '06
From Maui, Hawaii
I routed my amp ground to the bolt that holds the rear driver-side passenger seat belts (beneath the seat). Also, try rechecking the rest of your amp wiring ie: power wire and remote and see if any of them are loose.
This post has been edited by netrata: Apr 1, 2007 - 8:59 PM
post Apr 2, 2007 - 7:33 AM
applejax
Joined Mar 16, '07
From the gap that lies between one microsecond and the next...
QUOTE(xpokeme @ Apr 1, 2007 - 8:46 PM) [snapback]542110[/snapback]
I saw similar posts floating around, not sure if they were yours, so excuse me if some of this was already covered...
Make sure your ground is a solid contact onto bare metal. Get some sandpaper out if you have to.
Check all fuses.
Unhook the speaker wires. Does the amp still go into protect mode?
Unhook the RCA's. Does the amp still go into protect mode?
You didn't let the smoke out, did you?
The poster is not bound by any accuracy, stated or implied, of the previous post. Any similarities to actual people, fictional or real, may or may not be a coincidence.
--applejax
post Apr 2, 2007 - 10:47 AM
Ive been told, ground wire of an amp, should not be more than 2 feet long.
post Apr 3, 2007 - 6:29 PM
Redline08
Joined Feb 23, '07
From Albany, NY
i hooked my ground up to a bolt on the back on the right side passenger seat, my amp works fine
post Apr 3, 2007 - 7:05 PM
xpokeme
Joined Jan 18, '06
QUOTE(applejax @ Apr 2, 2007 - 7:33 AM) [snapback]542280[/snapback]
Check all fuses.
Tried everything and still doesn't work.. could it be my wires er sumtin? should i buy a new one? lol diz sukkS!
post Apr 4, 2007 - 8:09 AM
applejax
Joined Mar 16, '07
Curious, what (brand of) amp is this we are discussing? Does the owner's manual give a specific cause for the symptoms you are experiencing?
I am gathering from your original post in this thread that it does not go into protect until the remote turn on signal is sent, correct?
Are there other amps in your system? If so, with the RCA's and speaker wires removed from the amp in question, remove the power wires or fuses of the other amps at the d-block, and remove their remote turn-on leads as well.
Do you still get the pretty red LED?
--applejax
post Apr 4, 2007 - 5:13 PM
xpokeme
Joined Jan 18, '06
QUOTE(applejax @ Apr 4, 2007 - 8:09 AM) [snapback]543032[/snapback]
I have the dual 12' sub wit 580 amp.. when i unplug everything from the amp and install it bak in the led turns to red for like a second and turns off. when i remove the key and put it bak in the ignition theres no power to the amp and it doesnt even turn on.. so i dont know. any other suggestions?
post Apr 5, 2007 - 9:29 AM
applejax
Joined Mar 16, '07
QUOTE(xpokeme @ Apr 4, 2007 - 6:13 PM) [snapback]543189[/snapback]
Little confused here...
Are you saying the amp now appears to be totally dead?
--applejax
post Apr 11, 2007 - 2:22 AM
XS4lv1Truch0x
Joined Dec 9, '05
From Long Beach
check your blue remote turn on wire, make sure its hooked up to the receiver and the amp
and do you have your amp directly hooked up to the battery or are you just tapping into a 12v + wire?
and if the blue remote turn on wire is good than maybe you should try another ground. see how that goes.
Is this good enuff 4 ya? :D
post Apr 11, 2007 - 12:34 PM
celi_gt_racer
Joined Feb 6, '03
From huntingdon tennessee
are you sure that your amps rated power is at the same resistance ur subs are running at?
for example... is your amp running 1 ohm stable, 2?, 4? ... and whats the resistance per sub? ... could be your running too low impedence to your amp and it's protecting itself from frying biggrin.gif
post Apr 11, 2007 - 7:09 PM
xpokeme
Joined Jan 18, '06
QUOTE(XS4lv1Truch0x @ Apr 11, 2007 - 2:22 AM) [snapback]545527[/snapback]
yeah my wire is hooked to amp and head unit. its powered wit the 12v wit the fuse. tried mostly everything but still wont work.
QUOTE(celi_gt_racer @ Apr 11, 2007 - 12:34 PM) [snapback]545631[/snapback]
my amp goes to protect even though its not hook'd up to the subs
post Apr 13, 2007 - 8:09 PM
xpokeme
Joined Jan 18, '06
okay now my amp doesnt even go to protect anymore, it doesnt turn on at all...could it be that my amp is busted? man diz sukks!!
post Apr 13, 2007 - 9:19 PM
CelicaST_CALI
Joined Feb 28, '07
From Banland
o dam,it might be fryed.Wat is the amp and subs?Did u get the amp of ebay or used or is it brand new.
BANNED. for life, you moron.
post Apr 14, 2007 - 12:21 PM
xpokeme
Joined Jan 18, '06
QUOTE(CelicaST_CALI @ Apr 13, 2007 - 9:19 PM) [snapback]546588[/snapback]
i bought it from best buy, brand new. got it on the thanksgiving sale for 119 both amp and sub. its the dual.
Lo-Fi Version Time is now: September 3rd, 2026 - 11:15 PM
