Apr 8, 2007 - 9:09 PM
![]() Enthusiast ![]() ![]() ![]() Joined Feb 27, '07 From cape coral/ft myers florida Currently Offline Reputation: 7 (100%) |
what do you guys do to keep your couplers from poping off your intercooler piping? i just tryed sealing it with high temp silicone then clamping it down but i only did it in one spot to see if it would work. so far so good
-------------------- ![]() BOOST GETS YOU LAID!!!! |
Apr 8, 2007 - 10:46 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Dec 14, '06 From MN, USA Currently Offline Reputation: 2 (100%) |
T-Bolts!!!!
Apr 8, 2007 - 11:10 PM
tbolts. in almost 3yrs i have not had a single pipe come loose with them installed.
Apr 8, 2007 - 11:14 PM
^^^ Tbolts are indeed the way to go.
Apr 9, 2007 - 2:10 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 1, '05 From Charlotte NC Currently Offline Reputation: 14 (100%) |
X2 its a necessity...
Apr 9, 2007 - 4:43 AM
![]() Enthusiast ![]() ![]() ![]() Joined Aug 28, '04 From FLA USA Currently Offline Reputation: 4 (100%) |
T-bolt clamps will hold them for sure in most cases.
For higher boost application, use t-bolt clamps and get some bead weld on the ends of the piping or flare them. This post has been edited by Gary: Apr 9, 2007 - 4:44 AM -------------------- _Gary
Apr 9, 2007 - 11:05 PM
![]() Enthusiast ![]() ![]() Joined Jan 13, '06 Currently Offline Reputation: 0 (0%) |
put some deep scratches on the ends of the pipe.... spray brake cleaner on then before putting'em on......works for me.......but i'm only pushing 10psi
| Lo-Fi Version | Time is now: September 11th, 2026 - 11:08 AM |
