> Easy Oil Change Valve
post Apr 26, 2007 - 5:27 PM
eyohannie
Joined May 20, '05
From San Diego, California
Has anyone seen this before?
It's a valve that you screw on your oil pan and it makes easier for you to drain your oil.
Any reviews?
http://lubricationspecialist.com/front/sho...aspx?fileid=105
post Apr 26, 2007 - 6:49 PM
alltracman78
Joined Aug 9, '06
From Ma
Um, why?
It doesn't exactly take a lot of effort to loosen a 14mm bolt and remove it, then clean the hole, reinstall new gasket if needed, and tighten bolt.....
post Apr 26, 2007 - 6:51 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
i used them all the time for deisel trucks, 8 gallons pouring down...makes it ez
Lo-Fi Version Time is now: August 30th, 2026 - 3:29 AM
