> valve cover, repainted a new color.
post Apr 27, 2007 - 2:59 PM
decided to paint my valve cover again, since i had it off and it was pretty dirty. i really wanted to paint it a metalic gold, but it seems like no one sell that color in a high temp paint. anyway, here is how it turned out.
This post has been edited by lagos: May 16, 2007 - 4:23 PM
post Apr 27, 2007 - 3:44 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
Looks nice.
post Apr 27, 2007 - 3:54 PM
jdmart
Joined Mar 7, '07
From dallas texas
id like to to that one day is it easy and simple? will i have to change my oil to?
DRIVE UP..........
ACCEPT THE CHALLENGE.........
DESTROY YOUR OPPONENT.........
post Apr 27, 2007 - 4:12 PM
phattyduck
Joined Dec 5, '05
From LA, CA
How do you clean it before you paint it? My valve cover is pretty dingy (at least it matches my car!) and it seemed almost impossible to clean when I had it off the motor. Someday I'd like to paint it (or maybe just clean it) back to a nice clean aluminum color.
-Charlie
2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid
1988 Camry Alltrac LE - BEAMS swap started
post Apr 27, 2007 - 4:25 PM
i used a paint stripper on it first. that removed a lot of the old paint i had on there as well as any grease there was. then i cleaned the surface with alcohol. then i did 3 coats of primer... masked off the letting with tape and painted it blue. then 3 coats of paint ..and 3 coats of clear.
post Apr 27, 2007 - 4:57 PM
6strngs
Joined May 12, '06
From Wilmington, NC
nice. I painted mine blue using duplicolor engine paint and primer. looks so good!
post Apr 27, 2007 - 9:12 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
Looks good. I would do this if you could see mine.
I will return one day.
post Apr 28, 2007 - 12:15 AM
toyotacrazy
Joined Mar 4, '06
From Ohio
QUOTE(defgeph @ Apr 27, 2007 - 9:12 PM) [snapback]551707[/snapback]
Looks good. That must be an mr2 valve cover
post Apr 28, 2007 - 2:47 AM
Slick
Joined Jan 10, '06
From Mozambique, Africa
for a 3SGE, would i just remove the plug cables, plugs, unscrew the valve and paint? Or do i have to prep the engine first (drain oil?)?
post Apr 28, 2007 - 3:04 AM
macavely
Joined Nov 4, '02
looking nice art.. but they do sell high temp paint in metallic gold.. i seen them in all the autozones around here.. i'm not sure what brand its..
post Apr 28, 2007 - 9:35 AM
QUOTE(macavely @ Apr 28, 2007 - 4:04 AM) [snapback]551813[/snapback]
must not be a popular seller. cause i checked 3 stores and none of them had it.
post Apr 28, 2007 - 9:59 AM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(Slick @ Apr 28, 2007 - 12:47 AM) [snapback]551812[/snapback]
you don't need to drain the oil. just need a new valve cover gasket.
and yeah, I think it's by dupli-color. my friend did his car with a metallic blue. and I think they had metallic gold there too.
post Apr 28, 2007 - 10:47 AM
devilsden97
Joined Jun 13, '05
From Poughkeepsie, NY
Looks good Art. I need to change the gasket for my valve cover, maybe ill clean it while im at it and paint it up.
Kawi Love
post Apr 29, 2007 - 12:03 AM
Alan
Joined Jan 23, '05
From Malta
QUOTE(lagos @ Apr 28, 2007 - 9:35 AM) [snapback]551836[/snapback]
I am also going to respray my valve cover, the paint I have is not really for high temp. applictions, and is is all bubbly now lol, but I am thinking of polishin it.
What do you think?
post Apr 29, 2007 - 9:00 AM
QUOTE(Alan @ Apr 29, 2007 - 1:03 AM) [snapback]552053[/snapback]
What do you think?
polishing it will take a lot of time and effort to get right and it might not last too long. if you can, you should have it powder coated.
post Apr 29, 2007 - 9:05 AM
What do you think?
polishing takes lots of time and effort, but looks incredible when done right.
clearcoating it with hi temp clear will really extend the life of the parts shine, and make it easier to keep it clean.
post May 16, 2007 - 4:23 PM
i ended up finding the color that i originally wanted. so i had to redo the paint ...again. i think its going to look really good in the engine bay.
post May 16, 2007 - 4:42 PM
brianforster
Joined Mar 3, '04
From Hollywood, MD
looks good, when i paint my valve cover im going to do a black with red toyota lettering, and do the heat shield black too.
can never have too much black in an engine bay!
post May 16, 2007 - 6:19 PM
Alan
Joined Jan 23, '05
From Malta
Much better !!!
post May 16, 2007 - 10:41 PM
99GT
Joined Dec 14, '06
From MN, USA
Very nice...! Sexy time....
Lo-Fi Version Time is now: August 23rd, 2026 - 2:26 PM
