May 8, 2007 - 2:35 PM
Enthusiast Joined Dec 3, '03 From Hamilton, MT Currently Offline Reputation: 0 (0%) |
Hey, I have a stupid problem. My celi missfires at the slightest little bit of load. (Taking off from stop lights, passing cars, etc.) Its the 7AFE, rebuilt by a crappy company with about 25,000 on the motor. I have replaced: distributor, fuel filter, alternator, plugs, wires, cap, rotor. In addition I have checked the fuel pressure out of the rail, checked the valve gaps, ignition timing, and cam timing, all of these were in spec. Does anyone have any ideas? I would really appreciate any help. Thanks.
This post has been edited by daphreakda: May 8, 2007 - 2:39 PM -------------------- You can lead a horse to water, but there is no way your VCR will benifit from it.
May 8, 2007 - 3:21 PM
![]() Enthusiast ![]() ![]() ![]() Joined Jan 9, '05 From green springs ohio Currently Offline Reputation: 1 (100%) |
check your compression of the motor you could have a leak , or posiably a vacuum leak in the intake manifold
May 8, 2007 - 6:14 PM
check the connections at the harnesses all over the engine for bad connections.
are you using stock plugs? if not use stock plugs. -------------------- |
| Lo-Fi Version | Time is now: September 20th, 2026 - 3:51 AM |
