> any one install a NEO on a 5s yet??
post May 19, 2007 - 2:11 PM
Valo666
Joined May 15, '05
From Toronto
So, i bought my self a Apexi AFC Neo today, and am plannin on wiring it up on tuesday when i have class. Has any one wired one of these up to a 5s yet?? I know Steph got one wired up to her ST, but not 100$ sure about any one with a GT. i donno if its like the SACFII, but its got a 15 wire wiring harness, but it says for a non v-tec, non RB26DETT, and a non- karman sensor vehicle, only use 9 of the wires. So pretty much you only need these wires: IG power, IG power *again*, RPM, throttel, ground, ground, airflow/pressure sensor, airflow/pressure sensor and illumination *ie power*. Does any one have a pic of a 5S pinout that can highlight these wires for me? Thanks
Bryan
post May 19, 2007 - 2:32 PM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
I whipped this up for you real quick, it's using the diagram for a '95 Auto, but it should be the same for you.
Click here to see my swaps
drtweak@phoenixtuning.com
post May 19, 2007 - 3:23 PM
Valo666
Joined May 15, '05
From Toronto
ty tweak. can some one with a stick verify this is the same pinout?? I dont wanna start connecting wires in the wrong places.
post May 19, 2007 - 3:51 PM
Dr_Tweak
Joined Mar 31, '04
Just compare it against the instructions, the Toyota diagrams are in the back.
post May 19, 2007 - 5:13 PM
Valo666
Joined May 15, '05
From Toronto
they dont list a 5sfe though, only 3sfe and i wanna make sure they are the same pinouts. Also in the neo book they r in the front.
post May 20, 2007 - 6:10 PM
6strngs
Joined May 12, '06
From Wilmington, NC
yeah, I've got one in my car. and yeah, it's the same for the 5s as the one in the book. only thing is, my car is a stick, but it still had a 22 pin connecter for the third one instead of the 12 like people are saying the manual tranny's have. maybe cause my car is cali spec?
I followed pressure2's how-to install a safcII and the wire colors are all the same.
This post has been edited by 6strngs: May 20, 2007 - 6:11 PM
post May 20, 2007 - 10:17 PM
Dr_Tweak
Joined Mar 31, '04
QUOTE(6strngs @ May 20, 2007 - 11:10 PM) [snapback]559786[/snapback]
The 5th gen Celica GT manual uses a 12-pin, all 6th gen GTs use a 22-pin. The ST manual uses a 12-pin, however.
-Doc
post May 20, 2007 - 11:45 PM
Valo666
Joined May 15, '05
From Toronto
thanks dude.
post Nov 10, 2007 - 8:30 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
on my car there pressure wire is missing from the ecu, where do i tap this?
post Nov 11, 2007 - 8:41 AM
QUOTE(LewFX @ Nov 10, 2007 - 9:30 PM) [snapback]613088[/snapback]
the pressure wire is there, jeff.
that is the map sensor signal, the car wont run without it.
post Nov 12, 2007 - 1:38 AM
6strngs
Joined May 12, '06
From Wilmington, NC
might be in a different place though cause you have an auto...
post Nov 12, 2007 - 1:55 PM
LewFX
Joined Jan 28, '05
what color is the pressure wire? i tapped a blue one
post Nov 13, 2007 - 1:04 AM
LewFX
Joined Jan 28, '05
anyone know what color the pressure wire is??
post Nov 13, 2007 - 1:34 AM
urbandork
Joined Jul 16, '04
From Los Angeles
QUOTE(LewFX @ Nov 12, 2007 - 10:04 PM) [snapback]613687[/snapback]
gray with black stripe
this worked for me but then again i was manual... if read the page below it say its "engine control module(engine and electronically controlled transmission (A/T), engine ecu (M/T))". does this mean they are the same? save and zoom in...
it puts the PIM pin out on the ecu as the small plug on pin 2 and the wire is gray with black strip
This post has been edited by urbandork: Nov 13, 2007 - 1:38 AM
post Nov 13, 2007 - 9:55 PM
LewFX
Joined Jan 28, '05
i dont have any grey blk wire, can anyone else can find there pressure wire on their ecu?
post Nov 13, 2007 - 11:49 PM
on the middle ecu plug, pin 2 from the right when looking at the plug connected to the ecu. should be gray with black stripe.
you can also look at the wires right on your map sensor, in the engine bay. you should have a brown wire ( ground ), gray with black stripe (signal for safc) and red (5v from the ecu).
post Nov 13, 2007 - 11:58 PM
LewFX
Joined Jan 28, '05
okay i checked the map sensors wires, its brown, blue and red
post Nov 14, 2007 - 12:45 AM
MaskedMan
Joined Jun 29, '03
From 캘리포니아
Yes, the #2 wire coming from the Map sensor is blue, so the blue wire you had tapped into should be the correct wire. You can verify this with an ohm test using a multimeter. It should be what you need. Just get the right injectors in there and we can tackle it from there.
Lo-Fi Version Time is now: August 31st, 2026 - 11:58 PM
