May 25, 2007 - 4:39 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 30, '06 From West Windsor NJ, USA Currently Offline Reputation: 14 (94%) |
Hey I was trying to install a trd spoiler on my coupe....I did not have a spoiler to begin with so I have no idea where the hole are....someone with a coupe and a spoiler please show me where the oem hole where....ty
This post has been edited by Daftboy: May 25, 2007 - 8:25 PM -------------------- ![]() --------------------------------私は銀行に漂う,TRD Inspired |
May 25, 2007 - 4:53 PM
![]() Enthusiast ![]() ![]() ![]() Joined Feb 27, '07 From cape coral/ft myers florida Currently Offline Reputation: 7 (100%) |
theres 4 black plugs on the underside of your hatch unplug those and u have to drill the holes through the deck lid......let a body shop do it you can really mess up you body causing rust
-------------------- ![]() BOOST GETS YOU LAID!!!! |
May 25, 2007 - 4:58 PM
id rather do it myself can't i just put rust preventer on it?
May 25, 2007 - 5:00 PM
QUOTE(Daftboy @ May 25, 2007 - 5:58 PM) [snapback]561560[/snapback] id rather do it myself can't i just put rust preventer on it? i guess you could but its pretty dificult getn the holes lined up. u really wanna drill the smallest holes possible -------------------- ![]() BOOST GETS YOU LAID!!!! |
May 25, 2007 - 5:02 PM
![]() Enthusiast ![]() ![]() Joined Apr 14, '06 From Vancouver, WA Currently Offline Reputation: 0 (0%) |
I would think that so long as the spoiler has some kind of grommet on the ends you should be fine, but you can take some preventative measures to prevent rust. Like painting the holes you've drilled. Just make sure to mask everything else off.
Measure twice and drill once! Good luck! QUOTE(jesterwr217 @ May 25, 2007 - 5:00 PM) [snapback]561561[/snapback] QUOTE(Daftboy @ May 25, 2007 - 5:58 PM) [snapback]561560[/snapback] id rather do it myself can't i just put rust preventer on it? i guess you could but its pretty dificult getn the holes lined up. u really wanna drill the smallest holes possible But if the wholes are only big enough to fit the studs and they're a little off then the stress on the spoiler can eventually cause it to crack, which is what happened when I put the supra spoiler on my 84 Celica. -------------------- |
May 25, 2007 - 5:05 PM
QUOTE(GTS13 @ May 25, 2007 - 6:02 PM) [snapback]561562[/snapback] I would think that so long as the spoiler has some kind of grommet on the ends you should be fine, but you can take some preventative measures to prevent rust. Like painting the holes you've drilled. Just make sure to mask everything else off. Measure twice and drill once! Good luck! QUOTE(jesterwr217 @ May 25, 2007 - 5:00 PM) [snapback]561561[/snapback] QUOTE(Daftboy @ May 25, 2007 - 5:58 PM) [snapback]561560[/snapback] id rather do it myself can't i just put rust preventer on it? i guess you could but its pretty dificult getn the holes lined up. u really wanna drill the smallest holes possible But if the wholes are only big enough to fit the studs and they're a little off then the stress on the spoiler can eventually cause it to crack, which is what happened when I put the supra spoiler on my 84 Celica. which is why you dont do it yourself lol -------------------- ![]() BOOST GETS YOU LAID!!!! |
May 25, 2007 - 7:12 PM
drilled it in....looks ok right now...i need too drill another set of holes thou still and those ones do not have a place for a hole so im confused
May 25, 2007 - 7:16 PM
QUOTE(Daftboy @ May 25, 2007 - 8:12 PM) [snapback]561610[/snapback] drilled it in....looks ok right now...i need too drill another set of holes thou still and those ones do not have a place for a hole so im confused did u pull out all 4 black plugs?? -------------------- ![]() BOOST GETS YOU LAID!!!! |
May 25, 2007 - 7:17 PM
on the coupe there is only 2
May 25, 2007 - 7:18 PM
hmm that could be a prob not too sure on that one i didnt notice you were a coupe b4
May 25, 2007 - 7:19 PM
I mean the title does say coupe =p
This post has been edited by Daftboy: May 25, 2007 - 7:20 PM -------------------- ![]() --------------------------------私は銀行に漂う,TRD Inspired |
May 25, 2007 - 7:21 PM
can u get some pics of the underside of the trunk lid and yea im blind haha
h/o ill go take one.....sorry its too dark out... I can take one tommorw
This post has been edited by Daftboy: May 25, 2007 - 7:23 PM -------------------- ![]() --------------------------------私は銀行に漂う,TRD Inspired |
May 25, 2007 - 7:24 PM
alright keep us posted ill try to help if i can
May 25, 2007 - 8:05 PM
Enthusiast ![]() ![]() ![]() Joined Dec 16, '06 From Maryland Currently Offline Reputation: 0 (0%) |
looks good, whats next on the list....you gonna go for the coomer look?
May 25, 2007 - 8:11 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 28, '07 From Banland Currently Offline Reputation: 1 (100%) |
Thast badass i love the trd wing on the coupe!!
| Lo-Fi Version | Time is now: August 27th, 2026 - 11:10 AM |
