> Any Mountainbikers on here?, Need advice re:- disc brakes
post Jun 7, 2007 - 8:13 AM
Racer_J
Joined May 16, '07
From Newcastle UK
I was wondering if there were any mountainbikers on here?? I could do with some advice regarding disc brakes...
I own a Klein Attitude Race mountain bike (yeah, I know it's an antique LOL) which I use all the time. I've been thinking of upgrading to disc brakes for a while, however, the frame has no provision to mount the rear caliper. Does anyone know if there are any clamp-on type calipers/brackets for frames that don't have mounts for disc brakes?
Any ideas or advice would be greatly appreciated.
Cheers
post Jun 7, 2007 - 8:43 AM
BigAl_UK
Joined Jan 10, '07
From Devon, UK
A couple of companies did do clamp on type fittings - in fact hope do one I think - I seem to remember there's was better than everyone elses because it had a bracing bar as the problem with non disk equipped bikes is that the stays often aren't designed to take the stress and so flex. Mind you Klein's aren't exactly known for flexing laugh.gif
This post has been edited by BigAl_UK: Jun 7, 2007 - 8:43 AM
post Jun 7, 2007 - 9:05 AM
Racer_J
Joined May 16, '07
From Newcastle UK
QUOTE(BigAl_UK @ Jun 7, 2007 - 2:43 PM) [snapback]566026[/snapback]
Yeah, the things as rigid as hell! Be a shame to get rid of the frame though, it's a really good bike. When it was new I was told it had "the stiffest rear triangle of any hardtail bike" LOL Hopefully it should be OK with a disc brake. Either that or I'll just stick with my V's
Cheers mate
post Jun 7, 2007 - 11:00 AM
BigAl_UK
Joined Jan 10, '07
From Devon, UK
QUOTE(Racer_J @ Jun 7, 2007 - 3:05 PM) [snapback]566031[/snapback]
Cheers mate
Given that most slowing braking is done with the front and the rear brakes more for steering (unless your a skid kid) then personally I would stick with V's on the back anyway unless you plough through really deep mud in the winter wink.gif
Oh, and if you do go for disks at the back - just be aware that if you sometimes trap the back wheel between your legs if your stopped to look at a view, catch your breath or have a better drink from your camelback then you can get really painful moon shaped burns from the disks if you are in hilly terrain wink.gif
This post has been edited by BigAl_UK: Jun 7, 2007 - 11:01 AM
post Jun 7, 2007 - 2:41 PM
Racer_J
Joined May 16, '07
From Newcastle UK
QUOTE(BigAl_UK @ Jun 7, 2007 - 5:00 PM) [snapback]566062[/snapback]
Cheers mate
Thanks for that mate. Maybe I'll just stick with the V-brakes on the back and go for a disk on the front instead.
Cheers
post Jun 8, 2007 - 12:50 AM
Sammyr
Joined Mar 28, '05
From Dunedin, New Zealand
I currently have a disk on the front and v brake at the back on my jump bike works fine as far as I am concerned
post Jun 8, 2007 - 1:20 AM
Racer_J
Joined May 16, '07
From Newcastle UK
QUOTE(Sammyr @ Jun 8, 2007 - 6:50 AM) [snapback]566307[/snapback]
Thanks for the info. I've just done a ride across country and noticed that I could have done with a bit more stopping power, especially on the off-road sections of the route. I've worn the brake blocks down quite a bit as a result, that's why I was looking at disks. Bearing what you've said in mind, I'll check out some front disks and see how things go from there.
post Jun 8, 2007 - 2:15 AM
creis
Joined Jan 10, '04
From Shoreline, WA
I have the same setup, disk in the frunt V in the back, I like the disk but the V stops faster, the disk is a much smoother slow to a stop (unless just slammed on the break then it can lock - and flip you up) I say keep a V in the back so it locks easy, but thats just what I like, I want that real strong grip in the back.
post Jun 8, 2007 - 3:02 AM
BigAl_UK
Joined Jan 10, '07
From Devon, UK
The other advantage of a front disk is I once blew a tyre because the rim overheated with a front V - this was doing a long descent off of Dartmoor on road and I had to keep braking because I kep getting stuck behind tourists in their cars laugh.gif Front tyre blew and I ended up in a hedge which was at least soft laugh.gif Disks don't make your rims overheat wink.gif
post Jun 8, 2007 - 3:54 AM
Racer_J
Joined May 16, '07
From Newcastle UK
Thanks guys. You've pretty much made my mind up for me! I've always thought that a rear disk would be more powerful than a V-brake but now it seems not necessarily the case. You've just saved me a fair bit of cash, thanks!
I'll let you know how I get on.
post Jun 26, 2007 - 9:40 PM
Stubble
Joined Jun 26, '07
From Winnipeg
Hey, I've got a question for you bikers. Do your bikes fit in the back of a 6gen? I have ST185 (5th gen), and I can fit 2 bikes inside the hatch - I was wondering if the 6gen is as roomy.
Thanks,
Brady
1990 ST185
post Jun 27, 2007 - 12:18 AM
Sammyr
Joined Mar 28, '05
QUOTE(Stubble @ Jun 26, 2007 - 9:40 PM) [snapback]572554[/snapback]
Thanks,
Brady
1990 ST185
Yup, no worries
I can get my downhill bike in with the rear wheel off and another with both wheels off (that is with both seats folded down)
post Jun 27, 2007 - 5:39 PM
pepsiman
Joined Jun 3, '06
what about with just the front wheel off? Will a bike fir then? (Sry if thread jacking)
post Jun 27, 2007 - 7:07 PM
Sammyr
Joined Mar 28, '05
QUOTE(pepsiman @ Jun 27, 2007 - 5:39 PM) [snapback]572931[/snapback]
I guess it depends on the bike a bit I cant get the dh bike in with only the front wheel off but i did manage to get my jump bike in the boot with both wheels on.
post Jun 28, 2007 - 6:55 PM
Stubble
Joined Jun 26, '07
From Winnipeg
Sounds good - good enough to consider a 6gen. I guess I really should just go have a look at one locally, even if it isn't the GT4 I want.
Brady
Lo-Fi Version Time is now: August 23rd, 2026 - 5:34 PM
