Jun 26, 2007 - 3:02 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 9, '05 From Oakland, Cali Currently Offline Reputation: 46 (100%) |
tried wd-40, pb blaster, goo-gone, thinner...EVERYTHING i can think of and these bastard things jus dont wanna get off me oem side skirts.... any tips?????
Jun 26, 2007 - 7:23 AM
![]() Enthusiast ![]() ![]() ![]() Joined Jul 8, '04 From Durham, NC Currently Offline Reputation: 6 (100%) |
QUOTE(DeW_H0e_GT @ Jun 26, 2007 - 8:02 AM) [snapback]572185[/snapback] tried wd-40, pb blaster, goo-gone, thinner...EVERYTHING i can think of and these bastard things jus dont wanna get off me oem side skirts.... any tips????? I used some bumper sticker remover that I bought from AutoZone I believe. What I did was scrape away as much as I could first, then spray the area well and wait 3 -4 minutes to let it soak in. Then I scraped off a little more. It takes a while but if you keep repeating this eventually you can get it all off. -------------------- ![]() |
Jun 26, 2007 - 2:18 PM
goood deal ill try it later....
Jun 26, 2007 - 2:25 PM
goo gone works, you gotta rub it in with your fingers not a towel. chanh thought me this and it works really well
Jun 26, 2007 - 2:30 PM
fingers huh?..ill try it....
Jun 28, 2007 - 2:58 PM
haha.. that took me a while to remove to...
. i used a torch and bumper sticker remover spray in tandem.. then after it became more pliable, i scraped and sanded it off. -------------------- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- |
Jun 28, 2007 - 3:58 PM
a towel just absorbs the goo gone and wont work, use fingers
Jul 6, 2007 - 10:54 PM
teh oem skirts have 2 clear film on the backside.....
the finger/goo gone trick works but only for the top portion....the bottom portion of the residue i jus use 60 grit sandpaper..and its REALLY messy..... -------------------- ![]() |
Jul 6, 2007 - 11:00 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Oct 18, '06 From cincinnati Currently Offline Reputation: 10 (100%) |
try some epoxy or rubber cement. rubber cement worked for me, but don't leave it on too long otherwise it'll just make the situation worse... g.l.
-------------------- proud =3sgte SWAPPED= '95 Celica ST owner [calling it the GT2 or half-trac]
309,000 miles n' .... |
Jul 7, 2007 - 12:31 AM
heat up the stuff maybe with a heat gun and its easier to rub off with your fingers.
Jul 7, 2007 - 2:11 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 14, '07 From Provo, UT USA Currently Offline Reputation: 25 (100%) |
QUOTE(DeW_H0e_GT @ Jul 6, 2007 - 9:54 PM) [snapback]575771[/snapback] teh oem skirts have 2 clear film on the backside..... the finger/goo gone trick works but only for the top portion....the bottom portion of the residue i jus use 60 grit sandpaper..and its REALLY messy..... huh... i just peeled mine off and they didn't have a sticky residue gl with that. -------------------- |
Jul 7, 2007 - 12:18 PM
Lol. If you peel off the clear stickers in a certain way it will get most of the residue off. You have to peel it off steadily and dont stop because if you stop pulling for a second it will leave a line of residue where you stopped. I don't know if that makes sense but anyway...
Jul 7, 2007 - 9:04 PM
Enthusiast ![]() ![]() ![]() Joined Mar 4, '06 From Ohio Currently Offline Reputation: 10 (100%) |
Mac tools sells a rubber/plastic attachment for a drill chuck. Its a wheel that you can spin right on paint and will remove glue, stickers, adhesive, etc. Just be carefull not to spend too much time in one spot or spin it up too fast. Itll take the paint right off! Especially on plastic. I believe you can get this for $15-$20.
Jul 9, 2007 - 2:44 PM
Interesting, would an auto store have this you think?
Jul 9, 2007 - 4:46 PM
QUOTE(RbrtNdrws @ Jul 9, 2007 - 2:44 PM) [snapback]576509[/snapback] Interesting, would an auto store have this you think? probably not. Ill try to find it on mac or snap on website |
| Lo-Fi Version | Time is now: August 31st, 2026 - 6:24 PM |
