Jul 2, 2007 - 4:20 AM
Enthusiast ![]() ![]() ![]() Joined Mar 14, '05 From Auckland,New Zealand Currently Offline Reputation: 1 (100%) |
One of my doors are not lined up(installed) properly by the last owner causing the top of the glass to hit the top rubber trim and not closing properly.
It is slightly tilted upwards away from the hinges instead of parallel to the body/ground. How do I go about adjusting it back? Pic shows what I am talking about(exaggerated view but u get the idea)
This post has been edited by soven: Jul 2, 2007 - 4:28 AM |
Jul 2, 2007 - 7:26 AM
Enthusiast ![]() Joined Jun 1, '07 From UK Currently Offline Reputation: 0 (0%) |
Hi there, I havent had time to look at the hindges on my car yet, But as far as im aware , cars dont genrally have adjustment as such?
If not would it be possible to pack the top hindge out to align the door better? Also u have any idea what make of spoiler that is? Looks nice! |
Jul 2, 2007 - 9:40 AM
measure the seams of the doors if they are ok all the way, maybe only the window needs adjusting..
Jul 2, 2007 - 12:11 PM
only thing that you might b able to do, loosen off the 2 screws that hold the door striker onto the frame, tap it down a bit. that should settle your door down a little bit.
Jul 2, 2007 - 5:12 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 14, '07 From Provo, UT USA Currently Offline Reputation: 25 (100%) |
QUOTE(nyawton @ Jul 2, 2007 - 6:26 AM) [snapback]574279[/snapback] Also u have any idea what make of spoiler that is? Looks nice! that spoiler came stock on the ssIII. it is just the stock 2post spoiler with risers if you want to put it on your car. just contact doggy or whoever is selling them. sorry to hear about your door bro. i hate it when little things like that happen. i love your car though. i wish i could get a hold of a ssIII. gl with getting it fixed. -------------------- |
Jul 3, 2007 - 2:50 AM
Thanks for the replies, If I look along the body line where the door meets quarterpanels.. I can see that the door is very slightly higher which seems to be the culprit. Will take a good look at the glass but I am pretty sure it is not the glass that is causing the problem.
As mentioned by other forum members, that is a stock ss3 spoiler. |
Jul 3, 2007 - 8:16 AM
Kewl
Jul 3, 2007 - 8:34 AM
![]() Enthusiast ![]() ![]() ![]() Joined Feb 27, '07 From cape coral/ft myers florida Currently Offline Reputation: 7 (100%) |
adjust the hinges inside the fender
-------------------- ![]() BOOST GETS YOU LAID!!!! |
Jul 3, 2007 - 12:40 PM
maybe this'll help: How to adjust your door
if you follow the how-to, you can adjust the metal plate inside the door striker up a notch. -------------------- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- |
Jul 3, 2007 - 2:45 PM
Just what I needed. Thanks guys. Will get onto it soon and report back
Jul 3, 2007 - 8:06 PM
Enthusiast ![]() ![]() ![]() Joined Feb 25, '03 From Springfield, MO Currently Offline Reputation: 1 (100%) |
be careful when adjusting the door
This post has been edited by b1gr3d: Jul 3, 2007 - 8:07 PM -------------------- Coming in 2010 full paintjob - new wheels - modified body - new interior - engine build- marriage |
Jul 8, 2007 - 5:25 PM
Would just like to update that I have solved the issue. Mucked about with the door striker for close to an hour before i decided it was going nowhere.
Removed front bumper. removed fender. Got to the top two hinge bolts, made it loose, shut door and then tightened them back up. All good after that. |
| Lo-Fi Version | Time is now: August 31st, 2026 - 5:52 AM |
