> Video Monitor Installation Help, New at Car Audio
post Jul 30, 2007 - 3:01 AM
MauiBuilt
Joined Nov 22, '06
From Maui, HAWAII
I recently posted a question about Power Distribution Block and found the answer on carstereo.com forum. I have a new question-I need to connect 2 A/V converter box that has 12v power wire(red), 12v accessory wire (yellow) and a ground wire (balck) to the connector. I pretty sure the red wire connects to the car battery and the black wire needs to coonected to an nearby bolt, but were do I connect the yellow wire?
post Jul 30, 2007 - 9:42 AM
lubu
Joined Apr 2, '07
From Great Western Plateau
QUOTE(MauiBuilt @ Jul 30, 2007 - 4:01 PM) [snapback]583599[/snapback]
yellow goes to + batt, red to accessory + and black to ground.
98% completion
aaRon
post Jul 30, 2007 - 2:49 PM
MauiBuilt
Joined Nov 22, '06
From Maui, HAWAII
QUOTE(lubu @ Jul 30, 2007 - 2:42 PM) [snapback]583646[/snapback]
You are right and I was wrong. So the accessory wire also connects to the battery? Will it be connected to the postive post or negative post?
post Jul 30, 2007 - 5:10 PM
lubu
Joined Apr 2, '07
um no..
yellow goes to positive batt
red goes to ignition on or accesorry +, meaning you connect red to a wire that feeds 12+ when you turn the key to on.
blacky to ground
98% completion
aaRon
post Jul 31, 2007 - 12:20 AM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
red and yellow wires are found behind the head unit with the adaptor harness for the new headunit smile.gif
Breaking Axles...
Lo-Fi Version Time is now: September 13th, 2026 - 1:07 PM
