> Power Antenna help?
post Jul 30, 2007 - 1:43 PM
Komail
Joined Jul 29, '07
x
This post has been edited by Komail: Sep 29, 2015 - 11:55 PM
post Jul 30, 2007 - 2:06 PM
bojangles_8686
Joined Nov 12, '02
From Baltimore, MD
Take off the plastic piece from the driver’s side of the hatch (make sure to unplug the small light on that panel). You don’t have to take it all the way off, once you undo enough of the clips/bolts holding it in you can bend it back enough to do what you need to do. That will expose the antenna assembly. There are a few screws that need to be undone, as well as unplugging the harness from the motor. I did this a long time ago so I don’t remember what you need to do to bring the mast through the hole in the panel but it should be pretty self explanatory. Hope this helps.
post Aug 8, 2007 - 3:40 PM
Komail
Joined Jul 29, '07
bump, can i use an aftermarket ebay antenna?
post Aug 8, 2007 - 5:36 PM
Redline08
Joined Feb 23, '07
From Albany, NY
you CAN use one but its gonna be hard to fit most likely, i dont know because my antenna broke at a car wash too a long time ago and i never bothered fixing it (cds ftw)
post Aug 8, 2007 - 7:18 PM
I JUST BOUGHT A MAST FROM
https://www.trademotion.com/partlocator/ind...amp;catalogid=2
FOR 35 BUCKS. I tried the honda 2000 antenna setu. Maybe i did not grip it tight. It got stolen biggrin.gif biggrin.gif
post Aug 8, 2007 - 11:31 PM
96bluevert
Joined Mar 19, '07
From Washington
S2K atenna FTW! Just make sure it's done correctly. theres a how-to on this site, not too hard at all to do.
post Aug 12, 2007 - 2:33 PM
ScoobyDooCruiser
Joined Oct 31, '02
From Boise, ID
Also, there's a how to on making a switch to be able to turn the power antenna off and on, so when you're listening to a CD the antenna doesn't go up. I did it, and its really easy, and worth it.
psalm 69
post Aug 12, 2007 - 8:36 PM
6gsillyca
Joined Jan 13, '06
From UnderTheGround403
QUOTE(ScoobyDooCruiser @ Aug 12, 2007 - 1:33 PM) [snapback]587419[/snapback]
Usually an aftermarket headunit should already have antenna up/down switch pre programmed. My ant only goes up when I select "tuner" for my music source. On cd or aux the ant goes/stays down.
post Aug 12, 2007 - 11:47 PM
duders
Joined Jun 13, '07
From Miami Beach, FL
Wait our Celica's come with power antenna's or what? Mines isn't so I barely have it up ( iPod-ready deck FTW!)
I have a '94 ST. I dont think it's power, but it would b nice to know. It's also cool looking smile.gif
Sorry it like posted twice
Lo-Fi Version Time is now: June 12th, 2026 - 10:15 PM
