> Engine Keeps cutting OFF
post Aug 6, 2007 - 12:29 AM
celica47
Joined Feb 3, '05
From Tampa, Florida
hey guys i recently ran into some trouble with the celi. After driving one day my car cut out, tried cranking again, after two or three tries it eventully fired up again. I drove a little longer and it died again! once i got it home i had rough ilding and sputtering. Btw during all this there is no loss of power to the engine so we can rule out any battery problems.
Things i have done:
Fuel injector cleaner
Vavoline Water Remover.
any ideas....
After adding the water remover the car drove fine for an hour, then i let sit and hasnt fired up since.....? I hope its just the fuel filter.
This post has been edited by celica47: Aug 6, 2007 - 12:37 AM
I'am Reinventing the SLow Lane.....
post Aug 6, 2007 - 8:18 PM
FortuneCookie
Joined Dec 12, '06
From Fob Sharana, Afghanistan
Engine Oil? Too much oil can cause those symptoms. Just a quick guess. Also check the distributor and valves psi.
This post has been edited by FortuneCookie: Aug 6, 2007 - 8:20 PM
post Aug 6, 2007 - 9:31 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
Yeah, are you getting spark to all cylinders? Check that.
**** Photobucket
post Aug 6, 2007 - 10:57 PM
celica47
Joined Feb 3, '05
From Tampa, Florida
Eh nah i doubt its the engine oil. Question, if my car wasnt firing on all cylinders why would it crank sometimes and drive for awhile?
post Aug 8, 2007 - 2:31 PM
celica47
Joined Feb 3, '05
From Tampa, Florida
Update: got the car to the shop mechanic tells me injectors are not getting signal but they are working.... Does they make any sense?
post Aug 8, 2007 - 3:23 PM
mneal2_92788
Joined Nov 7, '06
From Lawrence IN, 46226
mine did this a while back, i had a full tune-up and it was perfect after
Lo-Fi Version Time is now: August 25th, 2026 - 2:05 AM
