Aug 6, 2007 - 1:58 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Apr 22, '07 From Bay Area, California Currently Offline Reputation: 14 (100%) |
The Part # is TY2-HD00
Here is a website where they got a good deal on it, and with a lil info. Help me out guys, along with your opinion. Keep in mind, i need a clutch support a 5sfe w/ a ct26 project goin on. So i need something that will hold together. http://www.gripmotorsports.com/pi~pn~act_c...plate-2382.html This post has been edited by CaliJeff: Aug 6, 2007 - 2:02 PM -------------------- You say you don't understand how we go dumb, but have you ever been where i'm from?
-=-] Livin it in tha bay's a lil different [-=- |
Aug 6, 2007 - 7:17 PM
![]() Enthusiast ![]() ![]() Joined Dec 12, '06 From Fob Sharana, Afghanistan Currently Offline Reputation: 2 (100%) |
ACT clutch kits don't have 'stages'. When it comes to ACT clutches, you can mix them up. They have 3 different discs and 2 different pressure plates. The discs are as follows: Street Disc, 4 Puck Disc, and 6 Puck Disc. The pressure plates are as follows: Heavy Pressure Plate and Xtreme Pressure Plate. You can combine which ever that meets your standard and taste and driving style. I have the Disc and HPP. But it's close to stock gripping with a bit more force to it. HPP gets you about 45% grip where at XPP gives you about 55%-65% grip on the clutch. If I were you, I'd go for Xtreme Pressure Plate and Street Disc combo. The Street Disc allows you to shift more smoother and a bit faster and is closer to OEM disc which means it will last you longer than the other ones. The 'puck' discs will just allow the pressure plates to grip it much harder to get better transfer to the wheels. I would have gotten Xtreme PP with my Street Disc but I got my clutch kit for a good $200 almost brand new from a member on this forum. So I couldn't back that out.
This post has been edited by FortuneCookie: Aug 6, 2007 - 7:20 PM |
Aug 8, 2007 - 9:59 PM
are these the clutches ? -------------------- You say you don't understand how we go dumb, but have you ever been where i'm from?
Aug 8, 2007 - 10:21 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 12, '06 From Wilmington, NC Currently Offline Reputation: 45 (100%) |
that's the clutch disc. you also need a pressure plate which is part of a clutch kit. I'd use a street disc, a 4 and 6 puck are overkill for a 5sfte. then probably the Xtreme pressure plate, though you could probably get the Heavy pressure plate and be fine.
http://www.horsepowerfreaks.com/price/Toyo...tch/Clutch_Kits -------------------- ![]() 94 GT - Sold -------- 69 Pontiac Lemans - Sold 88 Alltrac - Sold ---- 04 WRX - Sold 00 GT-S - Sold ------ 91 Miata - project/drift car 95 GT - Sold -------- 96 GT - New Daily Drive |
Aug 8, 2007 - 10:45 PM
they dont have any xtreme PP w/ street disk pckges on that website nathan
Aug 9, 2007 - 4:02 AM
woops. my bad. but if you look on presure2's profile, he's using the heavy duty pressure plate with street disc, so, you'll be fine with that. Should be a little easier to drive that way too.
Aug 9, 2007 - 12:52 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined May 16, '05 From Toronto, Ontario Currently Offline Reputation: 8 (100%) |
presure2 is actually using a stock disc. (i asked him before, he's using the 00 disc) 00 is a stock disc.
they also hv the SS disc which is their performance street disc. no MM (modified street disc) disc for us there is another guy on here wif the SS disc... but i can't remember his username This post has been edited by elvasoshexai: Aug 9, 2007 - 12:55 PM -------------------- |
Aug 10, 2007 - 11:06 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Sep 6, '04 From oakdale Mn Currently Offline Reputation: 0 (0%) |
i have the act stock disc with heavy duty pressure plate. my oem setup was slippn like a mofo when i boosted. this setup is good for 250 whp and that's just where i want to be. it's a tiny bit harder to push in but the grip is unreal. i also have the fidanza flywheel.
This post has been edited by rjbibeau: Aug 10, 2007 - 11:07 AM -------------------- ![]() |
Aug 10, 2007 - 11:50 AM
kool, thanks for the input guys !
Aug 10, 2007 - 6:29 PM
Enthusiast ![]() ![]() ![]() Joined Jul 31, '05 From Southern California Currently Offline Reputation: 7 (100%) |
hehe my friends build those clutches, . i recommend the street disc and hdpp as well, you're not building a full on drag car.
Aug 10, 2007 - 7:57 PM
kinda OT..
but jesus christ... how long did it take u guys to get used to using these clutches??? the pedal isn't smooth like stock anymore... it springs up really quick... my car feels completely different now and i have to relearn to drive... i stalled like 40times in the parking lot going home from the mechanic =/ -------------------- |
Aug 10, 2007 - 9:20 PM
haha. I actually just stalled mine today. it's kinda embarrassing when you're first in line when the light turns green. but yeah, you get used to it after a while. I let my friend drive my car and stalled it too. lol. I only stall it once in a while, most of the time I can drive it regular. I have a spec stage 2 btw
Aug 10, 2007 - 9:30 PM
my pedal feels almost exactly the same, the only difference i noticed was being able to engage at higher rpm's easier while downshifting.
Aug 11, 2007 - 12:08 AM
QUOTE(airfron @ Aug 10, 2007 - 10:30 PM) [snapback]587073[/snapback] my pedal feels almost exactly the same, the only difference i noticed was being able to engage at higher rpm's easier while downshifting. really??? my pedal is not smooth at all... right around the catch point area it kinda springs up This post has been edited by elvasoshexai: Aug 11, 2007 - 12:10 AM -------------------- |
| Lo-Fi Version | Time is now: June 28th, 2026 - 6:24 PM |
