Aug 23, 2007 - 11:07 AM
Enthusiast Joined Oct 25, '04 From Newark NJ Currently Offline Reputation: 1 (100%) |
My car is now acting up after falling into this huge hole under a bridge that was hidden in the shadows. Now my car is making this horrible sound when ever I put the breaks on and when I take off from full stops. The sounds is like a clanking sound directly under the front passenger side. You can feel it on the floor of the car. I change my axle which was really chewed up, but i think it was like that before this incident and I also changed the strut. These things didn’t stop the weird clanking sounds. Anyone have any ideas?
Aug 23, 2007 - 11:49 AM
Enthusiast ![]() ![]() ![]() Joined May 3, '06 From New Hampshire Currently Offline Reputation: 2 (100%) |
Have you checked ur ball joint? sway bar links? maybe look at your drivers side and then look at your passengers to see if theres a difference. it sounds like u broke something if your hearing a clanking sound.
-------------------- ![]() Darin H. |
Aug 23, 2007 - 2:03 PM
Enthusiast ![]() ![]() ![]() Joined Feb 23, '07 From Albany, NY Currently Offline Reputation: 3 (100%) |
QUOTE it sounds like u broke something if your hearing a clanking sound dee dee dee lol i had to... something could be bent too This post has been edited by Redline08: Aug 23, 2007 - 2:04 PM |
Aug 23, 2007 - 5:36 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Jan 25, '06 From MN Currently Offline Reputation: 19 (100%) |
Jack the car up and inspect the area where the noise is coming from could be anything.
-------------------- "To Protect And To Serve The Wealthy" -POLICE
Aug 23, 2007 - 7:19 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 7, '03 From Northern Virginia Currently Offline Reputation: 23 (100%) |
i bet u it's your wheel bearing.
especially if it's a clanking |
Sep 30, 2007 - 4:32 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 1, '05 From Charlotte NC Currently Offline Reputation: 14 (100%) |
yeah, same thing happened to me... it is likely your bushings on your lower arm. after i got my swap i took mine to the track and the bushings finally gave out. unfortunately you cant just buy new bushings and you have to get a lower control arm ( i think its called a control arm) its shaped like a big A under your car. the bushings are probably torn.
| Lo-Fi Version | Time is now: September 12th, 2026 - 3:14 PM |
