> to bench bleed master cylinder, or not to bench bleed.
post Oct 5, 2007 - 12:17 PM
purplegt4
Joined Feb 7, '03
From Northern Virginia
I recently changed my brake lines. The brake fluid reservoir is empty. Must I bench bleed the master cylinder or just refill and bleed the brakes?
post Oct 5, 2007 - 12:31 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
refill and bleed like normal always making sure reservior is full
post Oct 5, 2007 - 1:09 PM
purplegt4
Joined Feb 7, '03
cool thanks.
post Oct 5, 2007 - 8:25 PM
start the bleeding from the longest line first...
post Oct 5, 2007 - 9:35 PM
Valo666
Joined May 15, '05
From Toronto
did your master go completely dry?..if so then bench bleed it just for peice of mine. If you had even a tiny bit, then just bleed all the lines like u regularly would.
post Oct 6, 2007 - 1:03 AM
purplegt4
Joined Feb 7, '03
QUOTE(Valo666 @ Oct 5, 2007 - 10:35 PM) [snapback]602252[/snapback]
yea i refilled and bled the system and am unhappy with the results. So now I have to bleed the master cylinder and the whole system again.
crapper.
Lo-Fi Version Time is now: July 11th, 2026 - 1:43 PM
