Oct 22, 2007 - 1:46 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Dec 14, '06 From MN, USA Currently Offline Reputation: 2 (100%) |
I've searched but maybe didn't search hard enough if there was a "how to" on this.
But can I get some advice/help. Auto Meter PRO-COMP Ultra lite Boost and Oil Pressure. Oil has three small 1ft long wires. Boost has a 1ft vac line, and black and white lines ( I think for the light? ) |
Oct 22, 2007 - 2:16 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jul 3, '04 From Yakima, WA Currently Offline Reputation: 1 (100%) |
i'll later post pictures of this (possibly)
but they're very easy to install - i give it a 2-3 hour install (mostly wiring) - what you'll have to do first is splice into the Black prim /Blue secondary wire (which is an Ignition wire) out of the back of the fuse panel inside the car. - then you're going to run your red lead from your lights to this splice. - you're black lead on the lights will have to be grounded to the chassis (ne screw or bolt to the chassis will do, mostly likely near the door) ------------- now with the vac/oil lines - for the vac - simply find any vacuum line off of the throttle body/ intake manifold. cut and T into that line with the provided vac line T. running that vac line T to the back of the vac/press gauge -for the oil line (im assuming its mechanical) i believe it's illegal/not smart to mount them inside the cabin, so its going to have to be mounted somewhere in the engine bay. which will be tapped into the oil pressure sensor bit which is right of the alternator and behind the exhaust manifold. - now, if you have an oil pressure sensor thats just a sender, you will T into the stock oil pressure sensor - and running a wire from the sender to the gauge inside of the vehicle. (it's automatically grounded so no need to ground it) hope this helps. -------------------- the 1/4 doesnt have patience for a ST.... so we make them ST-T's so atleast we'll sound good going slow.
Oct 22, 2007 - 2:50 PM
Oil is electric.
Oct 22, 2007 - 4:10 PM
it tells you in the instructions that come with those gauges.
Oct 22, 2007 - 5:06 PM
I bought the gauges off a guy on a local car forum for $40. So no directions. Sorry forgot to mention it.
Oct 22, 2007 - 9:36 PM
Oct 23, 2007 - 3:09 AM
QUOTE(99GT @ Oct 22, 2007 - 12:50 PM) [snapback]607343[/snapback] Oil is electric. thats why i put 2 different responses. -------------------- the 1/4 doesnt have patience for a ST.... so we make them ST-T's so atleast we'll sound good going slow.
| Lo-Fi Version | Time is now: May 17th, 2026 - 11:32 AM |
