Nov 6, 2007 - 11:37 AM
Enthusiast ![]() ![]() ![]() Joined May 19, '06 From North NJ Currently Offline Reputation: 16 (100%) |
where are both of these located? i read in a thread that the brake fluid reservior is located all the way in the corner of the engine bay closest to the steering wheel, then someone said that was the clutch fluid? can someone correct this before i make my way to autozone to get some dot 3 brake fluid? oh and both the clutch and brake fluid take dot 3 brake fluid correct?
Nov 6, 2007 - 12:07 PM
There is no clutch fluid. Theres something for the transmission called "gear oil" specifically for manual transmissions. Unless you have an automatic which needs ATF. automatic transmission fluid. You dont have an automatic and to put gear oil in you will have to get to it by going under the car and the fill plug is on your tranny. You just need brake fluid.
Nov 6, 2007 - 12:14 PM
QUOTE(bccentaur3 @ Nov 6, 2007 - 12:07 PM) [snapback]611732[/snapback] There is no clutch fluid. Theres something for the transmission called "gear oil" specifically for manual transmissions. Unless you have an automatic which needs ATF. automatic transmission fluid. You dont have an automatic and to put gear oil in you will have to get to it by going under the car and the fill plug is on your tranny. You just need brake fluid. thank you, good sir |
Nov 6, 2007 - 12:15 PM
Thank you. Any time.
| Lo-Fi Version | Time is now: August 27th, 2026 - 7:10 AM |
