Nov 7, 2007 - 1:34 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 28, '07 From Banland Currently Offline Reputation: 1 (100%) |
Well i thought id make my own custom box but now im thinking not,what do u guys think of these,there reviews are great,but id need to get a big amp to power them.Concerns,questions,comments?
![]() http://www.crutchfield.com/App/Product/Ite...2122&tp=112 Details: *ported enclosure with two 12" db Series subwoofers *3/4" MDF construction with front-panel ABS trim * polypropylene woofers with Santoprene rubber surrounds * 2-ohm mono impedance (1 set of heavy-duty binding posts) * Power Port venting technology * frequency response: 27-200 Hz * power handling: 750 watts RMS (1,500 watts peak power)<<<<<<<<<<< * sensitivity: 103 dB * 34-1/4"W x 16-1/4"H x 17-1/4"D1 x 13-1/4"D2 * warranty: 1 year + ![]() http://www.crutchfield.com/App/Product/Ite...7501&tp=115 # mono subwoofer amplifier # 375 watts RMS x 1 at 4 ohms (750 watts x 1 at 2 ohms) # variable low-pass filter (50-200 Hz at 24 dB per octave) # variable bass boost (0-18 dB at 40 Hz) # subsonic filter (12 dB at 25 Hz) # wired remote bass level control # Class D design # CEA-2006 compliant # speaker-level inputs # preamp outputs # fuse rating: 40A x 2 # 4-gauge power and ground leads with 80-amp fuse recommended — wiring and hardware not included with amplifier # 14-11/16"W x 2-5/16"H x 9-5/8"D # warranty: 2 years This post has been edited by CelicaST_CALI: Nov 12, 2007 - 10:23 PM -------------------- BANNED. for life, you moron.
Nov 7, 2007 - 2:14 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jul 7, '06 From Los Alamos, NM Currently Offline Reputation: 1 (100%) |
sounds like a great sub...
heard a lot of good things about polk though butttttttt im not a fan, id rather have a alpine type x for a jl w6 or w7 -------------------- 2015 Subaru WRX. World Rally Blue/Black
2001 Honda S2000. Spa Yellow/Black |
Nov 7, 2007 - 10:17 AM
Enthusiast ![]() ![]() Joined Jun 13, '07 From Whitby, ON, CAN Currently Offline Reputation: 6 (100%) |
MTX Cheaper and same quality. Polks are very nice though but are pricy. I used to work at Futureshop. I would only go with MTX, Image Dynamics, Infinity (higher quality not entry level). JL or POLK... no others.
MTX IMO is the best for the price though |
Nov 7, 2007 - 11:25 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Oct 31, '03 From Orlando, Florida Currently Offline Reputation: 0 (0%) |
they look nice... ive also heard great things about polk... whatever sub you get, just match it with the correct power and youll be good
Nov 10, 2007 - 6:09 PM
bump
Nov 11, 2007 - 5:29 PM
im thinking of powering them with this,good?:
http://www.crutchfield.com/App/Product/Ite...b=detailed_info -------------------- BANNED. for life, you moron.
Nov 11, 2007 - 6:54 PM
QUOTE(CelicaST_CALI @ Nov 11, 2007 - 5:29 PM) [snapback]613281[/snapback] im thinking of powering them with this,good?: http://www.crutchfield.com/App/Product/Ite...b=detailed_info -------------------- 2015 Subaru WRX. World Rally Blue/Black
Nov 11, 2007 - 7:48 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Nov 12, '03 From Crestview, Florida Currently Offline Reputation: 2 (100%) |
I like Polk.
Nov 11, 2007 - 7:57 PM
wow thats cool blinky^^^^^ wat subs and amps are those?how do they sound,i have been reading reviews for these subs and there all 5.0 outta 5.0,only prob is how big they are.
This post has been edited by CelicaST_CALI: Nov 11, 2007 - 7:57 PM -------------------- BANNED. for life, you moron.
Nov 11, 2007 - 8:54 PM
Two 12in. Polk MM2124 series running off the Polk C300.2 amp. Sounds nice and crisp. Exactly what I needed. Box was custom built to fit snug in the trunk. I have Polk db6750 components (front) and Polk db650 coaxial running off of the Polk C400.4 amp.
Nov 11, 2007 - 9:49 PM
sounds loud^^^wat do u think of the wiring of polk?
Nov 11, 2007 - 10:09 PM
Enthusiast ![]() Joined Oct 20, '07 From North Charleston, South Carolina Currently Offline Reputation: 4 (100%) |
i was lookin at the pic of that kenwood amp and the specs and your gonna run into some probs if you buy it because your going to be trying to run two subs off a mono channel amp.
Nov 11, 2007 - 10:13 PM
There are no problems with running 2 subs off of one mono amp. My friend has been running his for over 3 years now, problem free.
This post has been edited by BLINKYxMUNKEY: Nov 11, 2007 - 10:14 PM -------------------- |
Nov 11, 2007 - 10:17 PM
what i meant was you wont get as much power to both subs, i would prefer buying a 2 channel amp but thats just me
Nov 11, 2007 - 10:27 PM
ya i thought of that,but thats around 600rms per sub isnt it??
This post has been edited by CelicaST_CALI: Nov 11, 2007 - 10:30 PM -------------------- BANNED. for life, you moron.
Nov 12, 2007 - 12:58 AM
if you wire them correctly you will actually get more power out of an monoblock amp for 2 subs.
the amp see's the 2 dual voice coil subs as a 1 ohm impeadence instead of an 2 ohm impeadence, so you get more power out of the amp -------------------- 2015 Subaru WRX. World Rally Blue/Black
Nov 12, 2007 - 1:08 AM
wat do u mean wire right,just buy high gauge wire?that wiring diagram is correct right?
Nov 12, 2007 - 9:29 PM
ok well i realized that these subs are 750rms TOGETHER so thats only 325 a peice....so i need to downgrade my amp.check orginal post
Nov 12, 2007 - 10:29 PM
Enthusiast ![]() ![]() ![]() Joined Jun 8, '07 From Houston, Texas Currently Offline Reputation: 1 (100%) |
my friend just got two 1200 w 12's from kenwood and a proaudo 2200 w for 350 install free XD
Nov 12, 2007 - 10:52 PM
and wat does that have to do with this....that lucky bitch...
| Lo-Fi Version | Time is now: August 26th, 2026 - 11:54 AM |
