> gte exheaust manifold, and downpipe
post Nov 7, 2007 - 2:21 PM
frosty
Joined Sep 1, '04
From Alabama
http://cgi.ebay.com/ebaymotors/mr2-Celica-...1QQcmdZViewItem
Does something like this seem like a good buy? I'm always "if-fy" on ebay stuff.
Just looking for opinions....
CLOSED on 25 acres!
-shop coming soon....
post Nov 7, 2007 - 5:14 PM
1bwilson
Joined Aug 30, '02
From Maryland
Go with a sotck 3sgte manifold and a KO or Berk downpipe.
Those will eventually crack and I hear the downpipe has to be ground down for the wastegate to open all the way.
Member of Team 5sfTe
post Nov 7, 2007 - 6:18 PM
jgreening
Joined Jan 17, '04
From Illinois
recent thread for you
post Nov 7, 2007 - 11:20 PM
QUOTE(jgreening @ Nov 7, 2007 - 6:18 PM) [snapback]612149[/snapback]
Read my mind.
post Nov 8, 2007 - 10:26 AM
frosty
Joined Sep 1, '04
From Alabama
Hey, I appreciate it guys. Nice read on the thread you linked too.
I've always read where it's said manifolds built like this will crack, but never read a reason for it. My educated guess would be that due to the heat changes and the metal constantly expanding/contracting would cause the crack where as the stock cast manifold would do this less.
(still, they look cool biggrin.gif lol)
This post has been edited by frosty: Nov 8, 2007 - 10:30 AM
CLOSED on 25 acres!
post Nov 8, 2007 - 2:07 PM
phattyduck
Joined Dec 5, '05
From LA, CA
QUOTE(frosty @ Nov 8, 2007 - 7:26 AM) [snapback]612294[/snapback]
Thin-walled stainless (or, almost stainless like much of the chinese crap) is much weaker than a big cast manifold. When it gets hot, it gets soft and can crack/break. Heat cycling is also an issue (like you mentioned). It might be ok if you were able to keep the turbo support bracket, but I doubt it fits with a manifold like that.
The stock manifold with the turbo support and a wrapped/coated downpipe with a support would be your best bet for reliable performance. The questionable gains, extra engine bay heat (if not wrapped/shielded) and reliability issues just make most aftermarket manifolds not worth it.
-Charlie
2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid
1988 Camry Alltrac LE - BEAMS swap started
Lo-Fi Version Time is now: September 16th, 2026 - 5:23 AM
