> Parts Needed
post Nov 17, 2007 - 9:15 PM
Celicam8
Joined Nov 17, '07
What parts are needed for suspension change?
I have Struts and eibach sport's... anything else neede?
post Nov 17, 2007 - 9:41 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
maybe new strut boots and new top mounts since the bearings might be blown. Lots of suspension grease. If sway bar bushings are still good don't bother, but having polyurethane bushings would make a nice upgrade. If you got money get some suspension technique sway bars. Then you're set unless you want the factory gt4 rear strut bar.
94 Celica gt white (sold)
post Nov 17, 2007 - 10:08 PM
Celicam8
Joined Nov 17, '07
Im talking about needed... a must have... not if you want..
post Nov 18, 2007 - 8:08 AM
jdg371
Joined Jun 14, '05
Your question is not clear, we don't know what exactly you are doing hence we can't pin point what you need. Suspension change can vary, you have stated that you have struts and Eibach springs, what else you would need? Maybe sway bars for better rotation and handling?
post Nov 18, 2007 - 9:45 AM
Celicam8
Joined Nov 17, '07
like when changing the suspension itself... are there misc items that will be needed...
post Nov 18, 2007 - 7:08 PM
Celicam8
Joined Nov 17, '07
any rubber parts needed or something speical... other than the struts, front insirts and springs..
post Nov 18, 2007 - 7:35 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
Well if you put it like that. You need tools, jack stands maybe a lift if you have access to one. You definately need a breaker bar to get those damn bolts off. hmmmm... Oh yes lots of wd40 or pb blaster. O yeah suspension grease and you are set.
post Nov 18, 2007 - 7:38 PM
Celicam8
Joined Nov 17, '07
there is a difference between suspension grease and other grease? other than tools and wd40 anything else.... can the old parts from the front suspension be used... like the rubber covers and the top of the spring thing..
is this stuff needed?
This post has been edited by Celicam8: Nov 18, 2007 - 9:12 PM
post Nov 19, 2007 - 12:09 AM
jdg371
Joined Jun 14, '05
If your rubber are broken and such, it would be a good idea to replace them. The bumpstops should be replaced if their jacked up.
post Nov 19, 2007 - 12:38 AM
Celicam8
Joined Nov 17, '07
i dunno if they are broken... any way of finding out before?
post Nov 19, 2007 - 12:42 AM
jdg371
Joined Jun 14, '05
ripped, tore up, in pieces?
post Nov 19, 2007 - 1:07 AM
Celicam8
Joined Nov 17, '07
post Nov 19, 2007 - 9:09 PM
Celicam8
Joined Nov 17, '07
how the hell you attach the strut to the rest of the init... i cant get both holes even
post Nov 20, 2007 - 12:36 AM
Celicam8
Joined Nov 17, '07
guess ya'll cant help me...
Lo-Fi Version Time is now: August 26th, 2026 - 5:34 PM
