Nov 24, 2007 - 9:12 AM
Enthusiast ![]() Joined Nov 23, '07 From massachussets Currently Offline Reputation: 0 (0%) |
i have a stock 97 st 1.8 and i want a 3s-gte engine how much do they cost and what else do i have to do to make it fit in my car basically how much would the whole project cost
Nov 24, 2007 - 12:37 PM
since you have an ST you'll need the GT motor mounts. You'll want to buy a front clip, unless you can find a complete motor with the parts that usually come in the a clip. You'll have to get your wiring harness done to work with the 3sgte. You'll also need a tranny because your ST tranny won't work. If you've read the stickies cost vary from 3000 to 4000 depending on resources and whos doing the swap.
Nov 24, 2007 - 10:46 PM
QUOTE(bccentaur3 @ Nov 24, 2007 - 12:37 PM) [snapback]617137[/snapback] since you have an ST you'll need the GT motor mounts. You'll want to buy a front clip, unless you can find a complete motor with the parts that usually come in the a clip. You'll have to get your wiring harness done to work with the 3sgte. You'll also need a tranny because your ST tranny won't work. If you've read the stickies cost vary from 3000 to 4000 depending on resources and whos doing the swap. my car is a front wheel drive manual car would i have to get a front wheel drive transmission ?or can i just use a awd manual transmission |
Nov 24, 2007 - 11:07 PM
with the awd tranny that comes with the 3sgte from the gtfours I'm not sure but I think you will have to do some modification to get it to work. You can go out and get the tranny off of a regular GT and it will bolt up. Did you read the stickies yet? It will help you tons.
Nov 25, 2007 - 7:57 AM
what r stickies sorry =(
Nov 27, 2007 - 1:16 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 20, '06 From Florida Currently Offline Reputation: 44 (100%) |
just buy a manual tranny from a celi GT and axles and it will mount right to the 3s. what part of mass are you from? im north of boston.
Nov 27, 2007 - 10:07 PM
i live in worcester so if i get the gt transmission it will bolt onto the 3sgte and that would make it front wheel drive?
Nov 28, 2007 - 12:57 AM
does it matter what year the gt transmission is as long as its a 6th gen transmission?
| Lo-Fi Version | Time is now: August 25th, 2026 - 8:25 PM |
