Dec 18, 2007 - 12:34 AM
Enthusiast ![]() ![]() Joined Oct 18, '07 From Orange County, CA Currently Offline Reputation: 3 (100%) |
what are transmission switch & heater control valve. what do they do and where are they located?
Thanks -------------------- |
Dec 18, 2007 - 4:21 PM
this is the heater control valve.
![]() when you turn the Hot/Cool dial on the climate control, you're basically opening or closing this valve via this cable. when set to hot, it opens the valve and lets hot coolant flow through the heater system inside. This post has been edited by azian_advanced: Dec 18, 2007 - 4:22 PM -------------------- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- |
Dec 19, 2007 - 1:43 AM
QUOTE(azian_advanced @ Dec 18, 2007 - 1:21 PM) [snapback]623883[/snapback] this is the heater control valve. ![]() when you turn the Hot/Cool dial on the climate control, you're basically opening or closing this valve via this cable. when set to hot, it opens the valve and lets hot coolant flow through the heater system inside. thanks bud. i guess that's where i was leaking coolant from. replaced now. -------------------- |
| Lo-Fi Version | Time is now: September 16th, 2026 - 5:19 PM |
