> suspension & handling
post Dec 23, 2007 - 12:38 PM
dagreat1
Joined Mar 27, '06
From Gainesville
Ok i've heared everyone talk about how for about 2 grand you can drastically improve the handling of your vehicle... well I saved up a little more than that and I have a stock ST that I'd like to fix up in terms of handling... so what should I do? i already hav a CF hood making the car a little lighter but can anyone point me in the right direction as to what else i should look to buy or do?
post Dec 23, 2007 - 12:47 PM
Coilovers
Sway bars
rear strut bar
lightweight 17s, and good tires
slotted rotors and Hawk/Akebono/EBC pads
and ur good
post Dec 23, 2007 - 12:52 PM
Shink
Joined Oct 28, '07
From UK
QUOTE(playr158 @ Dec 23, 2007 - 12:47 PM) [snapback]625230[/snapback]
Coilovers
Sway bars
rear strut bar
and ur good
Decat pipe / tuned exhaust
Cold air intake
(those working together might help throttle response a little)
Manual shift? Then how about a lightweight fly wheel?
And this one is free:
Strip out as much of the interior and sound proofing as you can handle.
Other than that, the ST is going to need a 3S-GE engine to be much quicker biggrin.gif
post Dec 23, 2007 - 1:12 PM
dagreat1
Joined Mar 27, '06
From Gainesville
haha i know i have a 3sgte in another celica.. this one is just for pure handling.... It is stick... does a light eight flywheel make a big difference?
and when u say lightweight 17's we talking about 20lbs?
post Dec 24, 2007 - 1:20 AM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
Try more like 15 lbs.
post Dec 24, 2007 - 5:31 AM
Shink
Joined Oct 28, '07
From UK
QUOTE(dagreat1 @ Dec 23, 2007 - 1:12 PM) [snapback]625237[/snapback]
Lightweight rims are getting lighter. These Rota Grid are 5kg (11lbs), though that might be the smaller rim. I think a good lightweight wheel is about 7kg (15lbs) now.
Haven't done it myself, but you can lose weight on the flywheel. This means that the engine has a lighter rotational mass to turn, so less inertia. This should result in slightly better transfer of torque to the wheels. Better engine acceleration means better vehicle acceleration. In other words, she should be a bit quicker and more responsive around gear changes.
This post has been edited by Shink: Dec 24, 2007 - 5:32 AM
post Dec 27, 2007 - 5:57 PM
dagreat1
Joined Mar 27, '06
From Gainesville
those are nice... but who would pay the extra 60 for light weight nuts?
post Jan 4, 2008 - 5:41 PM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(dagreat1 @ Dec 27, 2007 - 2:57 PM) [snapback]626109[/snapback]
if you've ever held 20 lug nuts at one time, you know that the weight can add up to a couple of pounds. lightweight lug nuts might save you 1/2 a lb. per wheel, maybe more. for the average joe it's not going to make a difference, but if you're shopping for lightweight wheels and willing to spend a few hundred dollars extra to save a couple lbs. per wheel, what's $60 to save another 1/2 lb?
post Jan 4, 2008 - 5:45 PM
i would pay $60 for LTW nuts....rotating mass is the BEST mass to get rid of.
1/2 per wheel x 4 wheels = 2lbs now do the science for rotating mass at various speeds
its much more than a 2lbs shave!
post Jan 5, 2008 - 3:46 AM
6strngs
Joined May 12, '06
From Wilmington, NC
btw 1/2 lb. per wheel is just a guess, it could be more if you're going from OEM 21mm toyota mag shank lugs to lightweight splined "tuner style" lugs. heck, even just regular "tuner-style" splined lug nuts weigh a lot less than OEM toyotas.
post Jan 8, 2008 - 1:47 AM
dagreat1
Joined Mar 27, '06
From Gainesville
someone told me that every pound on a wheel is actually equivilant to about 4 lbs in the car... is that true?
also i have an update... I think i was going to get this coilover kit at advance auto parts:
http://www.partsamerica.com/ProductDetail....artNumber=40782
I really don't know where to buy and what constitutes a good sway bar.
Like is this good? and do i just need the rear?
http://cgi.ebay.com/ebaymotors/2-REAR-Sway...sspagenameZWDVW
and where do the hell do i find rear struts for our celica
post Jan 8, 2008 - 1:59 PM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(dagreat1 @ Jan 7, 2008 - 10:47 PM) [snapback]629149[/snapback]
get a good brand name if you're getting coilovers. Tein or ground control or something of that nature. as for a sway bar, what you posted is just the sway bar end links. the only aftermarket sway bars for our cars are made by suspension techniques. and for rear struts, kyb gr2 (oem replacment) or koni yellow's are the only ones I know of. of course, if you buy a full coilover kit like tein you won't need them anyway. you can get all this stuff at www.horsepowerfreaks.com but that's probably not the cheapest place to buy it from.
EDIT: just realized that you posted eibach springs. those aren't coilovers, they're just lowering springs. they'll improve handling but not as much as a coilover kit would. if you do get those, you can find them a LOT cheaper than that too, so I wouldn't get them there.
This post has been edited by 6strngs: Jan 9, 2008 - 12:38 AM
post Jan 8, 2008 - 11:11 PM
thespacepanda
Joined Apr 12, '07
From Houston, TX
I hate it when companies can't keep their domains current. It's not hard.
This post has been edited by thespacepanda: Jan 8, 2008 - 11:19 PM
"He won't come out of the bathroom. He keeps telling us we're dark somethings and not his friends."
"Hmm. Ask him if he's the dragon reborn."
"What?"
"Just do it."
".......He said yes."
"Tell him you are not darklings. He should open up."
".......Sweet. Thanks."
"No problem."
post Jan 9, 2008 - 7:51 AM
dagreat1
Joined Mar 27, '06
From Gainesville
huh?
post Jan 9, 2008 - 9:52 AM
jason
Joined Oct 7, '06
From wyomissing pennsylvania
coilover- tein ss 1200
shocks- koni 400
sway bars- suspension tech 300
get the beefy end links from twosrus 80
better brake pads - 60
since you have a hatch look to get a rear strut bar to stiffen that up 200
also a good alignment to more handeling specific charactaristics will help alot too, it will have you going through tires faster, but the handling will eb improved - another 80
prices are ballparked, but thats a pretty good shopping list for a noticable gain, anything else you will notice, but in my opinion wont be that great. i still roll on 18's and handeling is still awesome. i have some 16's that are for fun, but they look stupid on the car imo and the handeling gains arent worth as much as turning heads
post Jan 9, 2008 - 10:00 AM
QUOTE(jason @ Jan 9, 2008 - 9:52 AM) [snapback]629509[/snapback]
shocks- koni 400
A) if you get TEIN SS coilovers you can remove "shocks" from that list....since coilovers COME with shocks (except for ground control)
B) an alignment is a NECESSITY after performing suspension work. it will REDUCE the rate you go through tires it does not make you go through tires faster rolleyes.gif a bad alignment (ie too much toe (in/out) too much neg. camber (helps in the corners but reduces braking performance), too much caster) these things will make you go through tires FASTER.
post Jan 9, 2008 - 11:10 AM
jdg371
Joined Jun 14, '05
OTS Koni Yellow - 650
OTS Ground Control - 400 [Custom if you prefer, but only if you have good calculations]
ST Sway Bars
Upgraded End Links
Front Strut Bar of Choice [NO Ebay]
GT4 Rear Strut Bar or any 3PT Rear Strut Bar [NO Ebay]
16x7-7.5 with proper offset, keep them under 15LB
215/45/16 Falken Azenis 615s
Agressive Alignment. An example would be 2.6F 1.6R [on my 00 GTS]
That should improve your handling dramatically.
post Jan 9, 2008 - 11:13 AM
2.6f and 1.6R being -camber ?
post Jan 9, 2008 - 11:18 AM
jdg371
Joined Jun 14, '05
yerp. forgot to state it. thats camber and I have 0 Toe F/R
post Jan 9, 2008 - 6:54 PM
thespacepanda
Joined Apr 12, '07
From Houston, TX
QUOTE(jdg371 @ Jan 9, 2008 - 4:10 PM) [snapback]629519[/snapback]
ST Sway Bars
Upgraded End Links
"What?"
"Just do it."
"No problem."
post Jan 10, 2008 - 1:07 AM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(thespacepanda @ Jan 9, 2008 - 3:54 PM) [snapback]629638[/snapback]
ST Sway Bars
Upgraded End Links
also, if you do get an alignment with some negative camber or w/e else, rotate the tires a LOT! like every 2,000 miles, so you can squeeze every bit of life out of the tires you can. For FWD cars, the rears cross forward and the fronts go straight back.
actually the best thing to do would be to flip the tire, but you need to dismount and remount the tire for that. and most places will charge like $50 for that, maybe more if you've got bigger wheels. and if you've got assymetrical tires you can forget it. directional tires will prevent you from being able to rotate from left to right so that'll shorten the life too. of course, directional tires usually give the best handling though.
This post has been edited by 6strngs: Jan 10, 2008 - 1:11 AM
post Jan 10, 2008 - 10:34 AM
jdg371
Joined Jun 14, '05
My directionals only lets me rotate Front to Rear and vice versa.
post Jan 10, 2008 - 10:50 AM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(jdg371 @ Jan 10, 2008 - 7:34 AM) [snapback]629809[/snapback]
exactly
QUOTE(6strngs)
assymetrical tires means it just gets mounted on the wheel with one side of the tire facing out and one side facing in. you can still rotate those fine, but they can't be flipped over. not many people actually flip their tires on occasion. spending $50 to flip the tires could just be money in your pocket towards a new set. so, unless you've got some mega expensive tires, or you work at or know someone that works at a tire shop and can get it done for free, almost nobody actually has their tires flipped occasionally. now me, I've got directional tires which prevent me from rotating side to side, and staggered sizes which prevents me from rotating front to back. but since i work at a tire shop i can flip my tires to make a left side tire into a right side one and vice versa, or I'll just rotate front to back anyway, the difference in size is negligable.
post Jan 10, 2008 - 10:24 PM
jdg371
Joined Jun 14, '05
I will be facing a similar dilemma, i will be running a staggered set of wheels for AUTOX 16x6.5 with 225/50 and 15x6.5 with 195/50 Potenza RE01Rs
post Jan 11, 2008 - 3:13 AM
6strngs
Joined May 12, '06
From Wilmington, NC
225 on a 6.5" wide wheel? I'm not sure, but I thought 225 was the widest recommended size for 7.0" wide wheels? and I assume you're putting the bigger wheels on the back? I don't know much about suspension tuning and auto-x, but I don't see how big rear tires would benefit FWD, wouldn't that just make you under steer more because the skinny front tires will lose traction quicker than the wide rear tires.
anyway, the tires I've got now are 195/50/15 in the front, and 195/55/15 in the rear. Yokohama AVS ES100's all around. I only got the staggered size cause I was getting the tires for free, 2 came off a miata, and 2 off an integra. anyway, these tires corner really good! they suck for getting traction with my 5sfte though, but I mostly equate that to moving down from 205 to 195. cornering is really really nice though. they're not expensive either. one of the cheapest you can get, but they don't last very long from what I've been told.
post Jan 11, 2008 - 5:03 PM
thespacepanda
Joined Apr 12, '07
From Houston, TX
If you buy your tires from Discount Tire (if you have one in the area) they will unmount and rotate directional tires for free if you have the road hazard package on the tires which is like $15 when you buy the tire. Gotta love it.
"What?"
"Just do it."
"No problem."
post Jan 11, 2008 - 5:53 PM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(thespacepanda @ Jan 11, 2008 - 2:03 PM) [snapback]630088[/snapback]
yeah, that's where I work. and I've only ever flipped a tire for a rotation once and it was for a big truck and we charged him like $75 for it. it's possible that they'll tell you they will, and then just rotate them front to back and tell you they flipped them. the salesman are sneaky and only care about you if you're giving them money. I could care less if a car wanted their tires flipped, I get paid by the hour, not on commission. wink.gif
post Jan 11, 2008 - 7:02 PM
thespacepanda
Joined Apr 12, '07
From Houston, TX
I know for a fact that they've flipped tires around for me because not all my tires are the same brand and some of my rims in particular have some "battle damage". I'm OCD enough to know which rim had which tire and when I get them rotated they do remount the tires.
Kind of a tangent from what we were talking about but a question on buying new tuner lugs....
What is the thread pattern for the bolts on our cars? From what I can gather its 12x1.5mm. Can anybody confirm this?
This post has been edited by thespacepanda: Jan 11, 2008 - 7:05 PM
"What?"
"Just do it."
"No problem."
post Jan 12, 2008 - 12:08 AM
dagreat1
Joined Mar 27, '06
From Gainesville
I work at sears so i can mount and dismount my tires for free and i'm pretty sure that for FWD all your wheels should be the same size. having bigger wheels in the back has no benefit... in fact i've been told that it is detrimental... oh and i have no idea mr. panda
oh yea and when people come in my shop and ask to do things like that when we techs are getting commision.. you better hope its a slow day or you'll be getting the "remount"
post Jan 12, 2008 - 4:36 AM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(thespacepanda @ Jan 11, 2008 - 4:02 PM) [snapback]630113[/snapback]
hmm, maybe the employees at the one near you aren't as lazy as the ones I work with. anyway, yeah, it's 12x1.5mm thread pitch. just the regular standard length ones should work.
post Jan 12, 2008 - 10:30 AM
jason
Joined Oct 7, '06
wider tires in the back will give you more traction, the car will slide say... 80% of the time front n back with a 180 tire
and the car will slide say the same 80% of the time in the front, but now only 60% of the time in the rear. you can go a little harder with extra grip in the back, and still have good cornering characteristics in the front with the "skinnier" tires that fit the geometry better
thats my outlook on it.
post Jan 12, 2008 - 12:07 PM
6strngs
Joined May 12, '06
From Wilmington, NC
well, I see what you're saying, but since you have more grip in the back, when you corner hard you're front tires will lose their grip before the rear tires and you'll understeer. with grippier tires up front, and less grippy ones in the back, that would promote more oversteer, right?
post Jan 15, 2008 - 10:50 AM
QUOTE(6strngs @ Jan 12, 2008 - 12:07 PM) [snapback]630242[/snapback]
the wider the rear tires/skinner the front = more understeer
staggered is run on FWD for looks not for performance. RWD run staggered because well they are RWD they naturally oversteer so that can afford wider rear tires/wheels.
trying to compenstate for a staggered setup on an FWD car with softer fronts and harder rears wouldn't prove much help.
This post has been edited by playr158: Jan 15, 2008 - 10:51 AM
post Jan 15, 2008 - 11:03 AM
jdg371
Joined Jun 14, '05
QUOTE(6strngs @ Jan 11, 2008 - 3:13 AM) [snapback]630016[/snapback]
I would actually run it vice versa. Bigger tires for the front and smaller tires in the rear. I would run the smaller tires in the rear to help with the rotation in tight turns for autocross. The wider tires is to compensate for the power that spins the tires horribly when I get to 2nd gear LIFT. At least in theory wise it works.
Lo-Fi Version Time is now: August 9th, 2026 - 10:05 AM
