Dec 30, 2007 - 8:19 PM
Enthusiast Joined Dec 30, '07 From Kent, United Kingdom Currently Offline Reputation: 0 (0%) |
I want to spray paint my valve cover, is it safe enough to un-bolt and remove it? or will i find it difficult to put back on, anythng i need to watch out for?
Cheers Matt celica SR This post has been edited by MattCelicaSR: Dec 30, 2007 - 9:08 PM |
Dec 30, 2007 - 8:27 PM
Enthusiast ![]() ![]() ![]() Joined Apr 12, '07 From Houston, TX Currently Offline Reputation: 4 (100%) |
Should be fine. You'll probably need a new rubber gasket since you'll probably tear the old one up in the process. They're not expensive. Just make sure to use high temp paint.
-------------------- "He won't come out of the bathroom. He keeps telling us we're dark somethings and not his friends."
"Hmm. Ask him if he's the dragon reborn." "What?" "Just do it." ".......He said yes." "Tell him you are not darklings. He should open up." ".......Sweet. Thanks." "No problem." |
Dec 30, 2007 - 9:04 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Apr 22, '07 From Bay Area, California Currently Offline Reputation: 14 (100%) |
i didnt tear mine up at all. if u havent removed the cover in awhile, get a rubber mallet and tap it a lil. should come up fine. i didnt have to replace my gasket. just dont be crazy with it.
-------------------- You say you don't understand how we go dumb, but have you ever been where i'm from?
-=-] Livin it in tha bay's a lil different [-=- |
Jan 1, 2008 - 3:03 AM
Didn't have problems with my gasket either..
Just be careful of your injector wires when putting it back on.. I accidentally got one caught and the timing gear caught it and exposed the wire grounding it. didn't figure it out for about 3 days.. made me miss a show I really wanted to go to -------------------- ~Daniel~ No Longer Celica Owner.. moved on to a 03 WRX-EJ207
Jan 2, 2008 - 1:23 PM
while your in there just replace it. cuz you dont know if the original one will bug out on you.
Jan 2, 2008 - 5:09 PM
Enthusiast ![]() ![]() ![]() Joined Dec 20, '07 From Valkeakoski, Finland Currently Offline Reputation: 0 (0%) |
QUOTE(thespacepanda @ Dec 30, 2007 - 8:27 PM) [snapback]626811[/snapback] Should be fine. You'll probably need a new rubber gasket since you'll probably tear the old one up in the process. They're not expensive. Just make sure to use high temp paint. Is it really that easy? Just open the bolts etc and it comes off, paint it, and put it back? What would be the right amount of power to screw the valve cover back on? XX Nm? -------------------- |
Jan 2, 2008 - 5:51 PM
i know my 3sgte is 14 inch pounds or 1.1667 foot pounds so i don't suppose these are much more than that
Jan 3, 2008 - 1:35 AM
Enthusiast ![]() ![]() ![]() Joined May 13, '07 From riverside, ca Currently Offline Reputation: 0 (0%) |
Sorry to ask my own own question in your post , but it is on the same topic
Can i paint my valve cover without taking it out of the car ??? how hard can it be ? Reason is , my gaskets are fine and i dont want to mess it up and end up with a leak |
Jan 3, 2008 - 2:15 AM
yeah but you might end up spraying something you don't want to... the valve cover gasket is $16 from toyota... it honestly just the screws on top.... remove any hoses connected and paint the cover... you can also take a peak and see what kind of condition the cams are in for instance... put the cover back on with the new gasket... tighten down to 14 INCH pounds which is just screwdriver tight without any heavy torque at all and you'll have no problem... i know i had to put some FIPG on the camshaft corners on my 3sgte but i don't know if its the same with the other engines... i assume so... its probably easier than actually painting the cover haha
Jan 3, 2008 - 12:23 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 13, '05 From Poughkeepsie, NY Currently Offline Reputation: 2 (100%) |
-------------------- ![]() Kawi Love |
Jan 10, 2008 - 4:28 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 2, '05 From Guam Currently Offline Reputation: 15 (100%) |
In my general theory of car mechanics, especially on aluminum material, there are sometimes sequences of how you unbolt and bolt back and torque.
Aluminum is very delicate. This post has been edited by trdproven: Jan 10, 2008 - 4:29 AM -------------------- 94 Celica GT
Jan 10, 2008 - 9:56 AM
Enthusiast ![]() ![]() ![]() Joined Jul 28, '06 From Delaware Currently Offline Reputation: 0 (0%) |
QUOTE(trdproven @ Jan 10, 2008 - 4:28 AM) [snapback]629777[/snapback] In my general theory of car mechanics, especially on aluminum material, there are sometimes sequences of how you unbolt and bolt back and torque. Aluminum is very delicate. I've seen the diagram ... now let me see if I can turn it up. *EDIT* Couldnt find a diagram, and from what I'm seeing it depends on what your torquing down, but for head applications most people recommend to start in the middle and work your way out to the ends. As for torque on the valve cover the 7a is listed at 14ft/lb. 14ft/lb isn't very much, and you dont want it to be, otherwise you will squish/crack/break the rubber washer that goes under the acorn nuts. Also, adding to Jaws, be very careful putting it back on as not to catch ANYTHING in between when putting it back on. When I did mine, the gasket didn't seat properly on the lefthand side after I tightened it up... part of the gasket got caught in the timing gear, and I had a big messy leak haha. Was an easy fix though, just put a lil FPIG where the gasket ripped and havent had an issue-but I have an extra VC gasket anyway This post has been edited by laff09: Jan 10, 2008 - 10:07 AM |
Jan 11, 2008 - 10:10 AM
QUOTE(Penkka @ Jan 2, 2008 - 5:09 PM) [snapback]627542[/snapback] QUOTE(thespacepanda @ Dec 30, 2007 - 8:27 PM) [snapback]626811[/snapback] Should be fine. You'll probably need a new rubber gasket since you'll probably tear the old one up in the process. They're not expensive. Just make sure to use high temp paint. Is it really that easy? Just open the bolts etc and it comes off, paint it, and put it back? What would be the right amount of power to screw the valve cover back on? XX Nm? Oh man, what was I thinking If i wanna make it look good, I should paint the manifold.. -------------------- |
| Lo-Fi Version | Time is now: June 10th, 2026 - 2:36 AM |
