Jan 12, 2008 - 9:49 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 20, '06 From Florida Currently Offline Reputation: 44 (100%) |
I have about 180 gigs of music on my exernal hard drive and i play it all through itunes. but what tends to happen about once a month or so, if the computer freezes or can't locate my hard drvie it screws everything up in itunes.
when i reconnect the external my itunes library cannot be found. as in if i play a song i get the message "the song ______ could not be used because the original file could not be found. Would you like to locate it?" so.. i have two options.. i can locate each song (38,000) or i can delete all of my songs in itunes, lose my playlists and reload them all in itunes.. (<this takes a few hours to load them all.) Is there a way i can reconnect the itunes player to the entire library it used to play? |
Jan 12, 2008 - 9:56 AM
Enthusiast ![]() Joined Sep 30, '07 From Ontario Currently Offline Reputation: 1 (100%) |
search for the Itunes Library file. Mine is in
c\documentsandsetting/chris/mydocuments/mymusic/itunes That Controls your Entire Library as well as playlists its an XML file This post has been edited by DangerboyJr: Jan 12, 2008 - 9:58 AM |
Jan 12, 2008 - 10:07 AM
Enthusiast ![]() ![]() ![]() Joined Jun 16, '06 From Bowling Green KY Currently Offline Reputation: 7 (100%) |
this might help bro, kinda similar problem
http://www.askdavetaylor.com/why_cant_itun...d_my_songs.html -------------------- **If you play My Brute, joing the 6gc.net clan!**
--A section of a kid's actual test that had been scanned-- ![]() |
Jan 13, 2008 - 12:09 PM
Well i imported the XML file, but if just brought up the exact same library that will not play. I attribute this to the fact that itunes must have saved my "broken" library when i closed it after it had not worked.. so it saved over the XML file of the working library...
i guess i will just reload them all in and copy the XML file of the working one when it works and back it up somewhere else so i can use it in the future without it getting saved over? |
Jan 13, 2008 - 12:46 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 14, '07 From Provo, UT USA Currently Offline Reputation: 25 (100%) |
can you install itunes on the external HD? then you shouldn't have a problem.
| Lo-Fi Version | Time is now: September 2nd, 2026 - 1:00 PM |
