> Sub/Amp Q', JL Audio
post Jan 21, 2008 - 9:30 PM
DSToyo
Joined Dec 16, '06
From Maryland
Hey, ive never done a sound system before, but i have two 12" JL Audio 12W0 8ohm subs. What need know is what kind of amp i would need to run these. Would a JL Audio 250/1 work? Im just a little thrown off by the 8ohm aspect of the subs. And how many channels i would need on the amp if i just wanted to run the subs. If anyone could give me a little info, and help clarify some things for me thatd be great. smile.gif
post Jan 22, 2008 - 12:26 AM
MaskedMan
Joined Jun 29, '03
From 캘리포니아
The JL Audio 250/1 will be a good amp to use with these subs as the 12w0 subs are made to perform well with little power. The nominal power for these subs are 125 Watt RMS. So the 250 will work well with them.
post Jan 22, 2008 - 11:45 AM
DSToyo
Joined Dec 16, '06
From Maryland
awesome, even with them being 8ohms. As you can see, i dont really know what exactly that means.
Would THIS amp work too?
Also what gauge wires should i be using?
This post has been edited by DSToyo: Jan 22, 2008 - 1:17 PM
post Jan 23, 2008 - 4:14 PM
DSToyo
Joined Dec 16, '06
From Maryland
bump
post Jan 23, 2008 - 6:17 PM
Driveby
Joined Sep 17, '05
From Newcastle / UK
Wire the two 8ohm subs in paralell then the amp will only see a 4ohm load and be twice as loud as running an 8ohm load.
See here on how to wire in paralell
1994 JDM GT4 WRC
post Jan 23, 2008 - 6:54 PM
DSToyo
Joined Dec 16, '06
From Maryland
alright thanks, that helps alot
my subs are 125watts each i believe, so how many watts should my amp be?
and also can someone explain the channels on some amps?
post Jan 24, 2008 - 3:14 PM
DSToyo
Joined Dec 16, '06
From Maryland
...and what gauge wires would be needed? 8?
post Jan 24, 2008 - 10:20 PM
itssteve
Joined Dec 14, '07
From yorktown Va.
8ga should work but i think that 4ga would be better and leave a little room if you wanna upgrade, and if you are getting a mono amp then you dont need to worry about the channels just wire the speakers in series to a 4ohm load and run it off of one channel.
post Jan 25, 2008 - 2:58 AM
DSToyo
Joined Dec 16, '06
From Maryland
aight yeah, thats what i was thinking thanks. what do ya mean by leaving room for upgrade?
post Jan 25, 2008 - 10:37 AM
itssteve
Joined Dec 14, '07
From yorktown Va.
4ga wire will be fine with power up to around 1200 watts so if you wanna get a bigger amp in the future you wont have to go threw all the trouble of running new wire and all that you will be fine just to put in the new amp
post Jan 25, 2008 - 5:20 PM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
use 4 gauge wire and go with the JL amp... the 250.1 is perfect at 4 ohms for those subs... wire them in parallel like said above... this is a pretty simple setup and should sound good... do not wire them in series... you do not want a 16 ohm load smile.gif... go with the link above for wiring in parallel
This post has been edited by pittfirefighter: Jan 25, 2008 - 5:21 PM
Breaking Axles...
post Jan 25, 2008 - 5:25 PM
DSToyo
Joined Dec 16, '06
From Maryland
ok thanks alot! that really helps, sounds pretty simple like u said.
so u wouldnt go with the alpine amp as an alternative then?
post Jan 25, 2008 - 5:32 PM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
no stick with JL stuff... they put a lot of quality parts in and have several more safety features... i've personally only ever liked alpine head units and speakers... thats just my preference though...
Breaking Axles...
post Jan 26, 2008 - 2:03 AM
DatDudeJoey
Joined Jan 23, '08
u should get a mmats amp there really nice with a 15 mmats dreadnut youll be pushing 1000 rms :] youll be killing 2 to 3 12's all day
Lo-Fi Version Time is now: September 1st, 2026 - 6:30 AM
