Jan 26, 2008 - 10:39 AM
Enthusiast Joined Jan 14, '08 From Maine Currently Offline Reputation: 0 (0%) |
I few months ago I blew a rod through my 7AFE motor and today I finally finished putting a new one in. The only thing is when I drive it the engine temp drops and the cheek engine light pops on. When I stop the engine temp come back up. I did not have this problem with the old motor. Did I do somthing wrong instailing the motor, or is this a new problem. I did store my car two months before doing the engine drop. Any thoughs why it is doing this????
Jan 26, 2008 - 11:17 AM
did you install the thermostat? a new thermostat? whats the check engine light code?
Jan 26, 2008 - 11:34 AM
check your codes, it will be stored in the ecu.
sounds like your thermostat is bad. but IDk why your getting a CEL. if you dont know how to check for codes go here: http://www.6gc.net/forums/index.php?act=ST...=55403&st=0 -------------------- Former Team 5SFTE pro member ;)
Jan 26, 2008 - 11:39 AM
QUOTE(Bitter @ Jan 26, 2008 - 11:17 AM) [snapback]634745[/snapback] did you install the thermostat? a new thermostat? whats the check engine light code? No I never installed a new thermostat, not hard to do might do that tomorrow to see if that solves my issue. I don't have a way of reading the engine light code so i'm not sure what the ligh code is. |
Jan 26, 2008 - 11:50 AM
QUOTE(presure2 @ Jan 26, 2008 - 11:34 AM) [snapback]634753[/snapback] check your codes, it will be stored in the ecu. sounds like your thermostat is bad. but IDk why your getting a CEL. if you dont know how to check for codes go here: http://www.6gc.net/forums/index.php?act=ST...=55403&st=0 looks like ya missed this -------------------- Former Team 5SFTE pro member ;)
Jan 26, 2008 - 11:51 AM
Yeah, I did. Does not show for the 7AFE motor though. Prob all the same though
Jan 26, 2008 - 11:59 AM
QUOTE(Blurr05 @ Jan 26, 2008 - 11:51 AM) [snapback]634761[/snapback] Yeah, I did. Does not show for the 7AFE motor though. Prob all the same though they are the same. 4a = 7a. same thing as far as codes. i am editing in links to the actual 94 7a and 5s codes, with instructions on testing the systems that create the code. -------------------- Former Team 5SFTE pro member ;)
Jan 26, 2008 - 12:29 PM
Alright, thanks for the code list
| Lo-Fi Version | Time is now: August 4th, 2026 - 2:13 PM |
