> Steering to the right
post Feb 23, 2008 - 5:28 PM
valerit1
Joined May 2, '06
From Nevada
When I go straight and let the steering wheel go, car pulls to the right.
It actually steers to the right, I can see the steering wheel rotating to the right.
I tried going in both directions to account for possible road incline - same - always to the right,
steers itself. Tire pressure is equal right and left ~38psi).
What can it be?
post Feb 23, 2008 - 6:44 PM
spolski07
Joined Jul 7, '06
From Los Alamos, NM
go to sears and get an alignment job
post Feb 23, 2008 - 8:01 PM
Jeunesse
Joined Aug 21, '07
From Toronto
get the tires balanced too while you're at it...
This post has been edited by Jeunesse: Feb 23, 2008 - 8:02 PM
-Derick
"In hoc signo vinces." In this sign thou shalt conquer."
Gone but never forgotten....
post Feb 24, 2008 - 8:42 AM
94TRDcelica
Joined Feb 4, '08
From UK
Ive got the same- I had electronic alignment done which made it better but not perfect!
The other three symptoms could be: worn shocks (on one side perhaps, or even the settings not equal on both sides), warped discs slightly rubbing on the right side and finally the tyres may have un even tread! For example the inner wall could be well low due to the suspension not being set up right!
I unfortunately have the case of shocks tyres and discs being worn and need replacement. And to top it all of my clutch is going too!
post Feb 25, 2008 - 8:13 PM
alltracman78
Joined Aug 9, '06
From Ma
If you're so inclined, swap your front tires side to side and see if it changes anything.
Make sure the pressures are ok as well.
If that doesn't solve it, do this
QUOTE(spolski07 @ Feb 23, 2008 - 6:44 PM) [snapback]645003[/snapback]
When you go make sure you let them know it's actually pulling [not just the steering wheel off center].
post Feb 25, 2008 - 8:22 PM
hongkongnerdboy
Joined Jul 26, '07
From riverside,CA
you have a ghost driving your car
This post has been edited by hongkongnerdboy: Feb 25, 2008 - 8:22 PM
post Feb 25, 2008 - 8:55 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
QUOTE(hongkongnerdboy @ Feb 25, 2008 - 8:22 PM) [snapback]645728[/snapback]
its probably rodney dangerfield
エキサイティングカーレーシングチーム!
Lo-Fi Version Time is now: June 24th, 2026 - 12:56 PM
