> Yes another tranny question.
post Feb 27, 2008 - 10:32 PM
importedhp
Joined Jan 11, '08
From Tampa, Fl
I got stuck buying a 94 St with a very poorly installed 3s. The car has the c52 tranny in it and as you can amagine it didnt hold up. I have the motor putting out 306hp to the wheels. I know it is common to use a 5sp tranny from a v6 camry/ solora. I found one from a 01 solora at a local junkyard. Is that the tranny that is being used?
post Feb 27, 2008 - 10:59 PM
jdg371
Joined Jun 14, '05
Yes.
post Feb 27, 2008 - 11:44 PM
celicaST
Joined Jun 23, '05
you have a 3s bolted to a c52? they dont bolt together so doubt it, you probably have the gt s54 tranny. yes you can use that tranny. you can also use the e153 from the mr2 turbo. has a shorter final drive i believe and also available with lsd.
post Feb 27, 2008 - 11:55 PM
_mikeE
Joined Sep 28, '07
From Toronto, ON
What car has a c52 tranny? never heard of it.
The GT tranny's are s54, and also if you're going to get the e153 tranny (mr2/solara/camry) which yes, available LSD in it, you're going to have to change out ur cables and shiftlinks, and make custom axles. (as so i'm told)
post Feb 28, 2008 - 12:34 AM
QUOTE(_mikeE @ Feb 27, 2008 - 11:55 PM) [snapback]646885[/snapback]
post Feb 28, 2008 - 12:56 AM
_mikeE
Joined Sep 28, '07
From Toronto, ON
Ah i c. I knew they had a different tranny, but never took much notice or research about it but thanks, now i know.
post Feb 28, 2008 - 9:09 PM
politicsareevil
Joined May 1, '03
From Houston , Texas
It wont bolt up..... the clutch plate doesnt match...
post Feb 28, 2008 - 10:52 PM
importedhp
Joined Jan 11, '08
From Tampa, Fl
QUOTE(politicsareevil @ Feb 28, 2008 - 9:09 PM) [snapback]647441[/snapback]
Yeah I have been looking at so many post I got my tranny codes mixed up. Sorry bout that. Does $750 sound reasonable for a 01 solora tranny with 74k miles? Ill still need the st205 rear mount and bracket correct?
post Feb 29, 2008 - 12:46 AM
laff09
Joined Jul 28, '06
From Delaware
QUOTE(importedhp @ Feb 28, 2008 - 10:52 PM) [snapback]647484[/snapback]
Ive heard of other e153s go for about that, not sure how many miles though. Correct.
Lo-Fi Version Time is now: September 1st, 2026 - 8:24 PM
