Mar 7, 2008 - 7:37 AM
Enthusiast Joined Mar 3, '08 From Cork, Ireland Currently Offline Reputation: 0 (0%) |
hey guys, anyone know where i can get white dials for my ST hatch. i found a few sets on ebay but i think there for the 2.0 models, i presume they wont fit!?! Ideas?
Mar 7, 2008 - 10:15 AM
why wouldnt them fit, just compare. Take a pic of your gauges and openit up in your computer and open ebay and see. e-mail the seller with your pic to see wht they think.
Mar 7, 2008 - 1:34 PM
Enthusiast ![]() Joined Feb 4, '08 From UK Currently Offline Reputation: 0 (0%) |
Yeah, NJ said!
The only differences are: The St205 has boost gauge, so don't get that! The other difference is kph or mph and also how far the speedo dials run up to. My lockwood dials came with a 120mph and 180mph dial face! Most companies however give you the option! -------------------- ![]() |
Mar 7, 2008 - 6:19 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 30, '04 From So Cal Currently Offline Reputation: 13 (100%) |
SS-III gauge -------------------- |
Mar 7, 2008 - 6:41 PM
Mar 8, 2008 - 7:37 AM
cheers for all the help lads, i get on it str8 away!
Mar 8, 2008 - 8:40 AM
QUOTE(94TRDcelica @ Mar 7, 2008 - 6:41 PM) [snapback]650462[/snapback] ![]() My dials are MPH so the jap dials wont work i think. That one in the pic diagram (kph-mph conversion) is perfect though, any chance you know where i can pick that up? |
Mar 8, 2008 - 2:55 PM
Enthusiast Joined Dec 30, '07 From Kent, United Kingdom Currently Offline Reputation: 0 (0%) |
Hi people
Im also thinking of getting some White Lockwood dials to replace my glow gauges, but i was wondering on how you fit them? My glow gauges were easy enough as the holes are big enough just to slip over the needles without having to remove anything. Are the lockwood dials just the same, just slide them over the needles? Cheers |
Mar 9, 2008 - 6:49 PM
Toc - Click here if your car is an import! Click here it your car is UK spec Matt: They come with installation instructions! But you can't slide them over the needles. Instead use two teaspoons to gently pry the needles off! You will however have to record with a mark where the needle rests without being stopped by the little black pin. Then once you've installed the face and pin you will need to instal the needle as you removed it and then wind it up over the pin so that its spring can be reset. this may take a few attempts to get perfect. I particularly found this quite difficult to do on the fuel and water gauges! The advert suggests that you can just slip them on but I did not find this to be the case but I did it ages ago and was very inexperienced with cars! This post has been edited by 94TRDcelica: Mar 9, 2008 - 6:51 PM -------------------- ![]() |
Mar 10, 2008 - 7:12 PM
QUOTE(94TRDcelica @ Mar 9, 2008 - 4:49 PM) [snapback]651099[/snapback] Toc - Click here if your car is an import! Click here it your car is UK spec Matt: They come with installation instructions! But you can't slide them over the needles. Instead use two teaspoons to gently pry the needles off! You will however have to record with a mark where the needle rests without being stopped by the little black pin. Then once you've installed the face and pin you will need to instal the needle as you removed it and then wind it up over the pin so that its spring can be reset. this may take a few attempts to get perfect. I particularly found this quite difficult to do on the fuel and water gauges! The advert suggests that you can just slip them on but I did not find this to be the case but I did it ages ago and was very inexperienced with cars! Maybe I should've spent my money on those Lockwood ones instead of the authentic Denso guages.... -------------------- |
Mar 11, 2008 - 4:55 AM
Yeah the lockwoods are pretty good! They light up well and have a cool white display during the daytime and depending on your led colour the background at night comes alive! The markings around the dials glow green!
Im still playing with different Led's for the best coverage, From what I hear the SMT ones are the best, just haven't got around to ordering any yet! When I do i'll probably be go for SMT white! Should look the nuts! -------------------- ![]() |
Mar 11, 2008 - 5:35 AM
QUOTE(94TRDcelica @ Mar 11, 2008 - 5:55 AM) [snapback]651863[/snapback] Yeah the lockwoods are pretty good! They light up well and have a cool white display during the daytime and depending on your led colour the background at night comes alive! The markings around the dials glow green! Im still playing with different Led's for the best coverage, From what I hear the SMT ones are the best, just haven't got around to ordering any yet! When I do i'll probably be go for SMT white! Should look the nuts! whoa, SMT for the interior gauges. They dont fit, they are miniature... They work with the radio trick i did. u can buy leds with smts mounted on them, yeah. Well you can use SMT, you will have to add resistors and have somewhere to mount them. But these babies can do the trick ![]() http://www.superbrightleds.com/mini-wedge.html -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Mar 12, 2008 - 12:28 PM
yeah, I meant led's with Smt's in them!
I mean these puppies!
| Lo-Fi Version | Time is now: July 31st, 2026 - 10:58 AM |
