3 Pages V   1 2 3 >
> 3S-GTE Guys.......Oil Cooler users within please.
post Mar 7, 2008 - 9:06 PM
Fastbird
Joined Jun 25, '05
From Fort Wayne, IN
So after finally picking up an oil temp gauge, I'm noticing a pattern that I DON'T like. My oil temps are hovering around 220° during normal driving and for the short 7 mile blasts I go down the highway, they climb into the 230°-240° range. This is being light on the car.
I have a feeling that it would DEFINITELY benefit from an oil cooler. So my question for you guys is how are you plumbing the cooler into the system, and what kind of cooler are you using.
I'm looking at two different styles of transmission coolers available at my Auto Zone that I work part time at. One is a simple tube running through fins, like the cheap ones you see. The other is like a minature radiator, bar and plate style.
My thoughts on where to plumb them in are initally to come in on the drain side of the turbo and use a scavenging pump to move it through the cooler back into the pan. I think this would provide the greatest amount of efficiency but definitely NOT the best cost margin. Other than this, I can't think of where to plumb it in.
And for those wondering, I have the temp sensor for the gauge mounted in the filter sandwich adapter with no problems noted.
Any pics, write-ups, or ideas on setups you guys might have?
post Mar 7, 2008 - 10:16 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
this is what im using
http://store.summitracing.com/partdetail.a...mp;autoview=sku
post Mar 7, 2008 - 11:43 PM
Fastbird
Joined Jun 25, '05
From Fort Wayne, IN
What I'm looking at is VERY similar in design to that except it's half the price and uses clamp fittings instead of AN fittings.
How do you have it plumbed in though?
I'm really considering the scavenging pump route because the turbo obviously is going to have the largest affect on the oil temps, but I'm worried that I'll end up pulling oil through the turbo faster than the engine is pumping it and would end up wiping out the bearings.
post Mar 8, 2008 - 1:08 AM
I know you almost never listen to my advice (its all good smile.gif ) but thats a bad idea.
If you want to install an oil cooler, you should go with one that attaches to the factory oil cooler.
Something like this would be the best way to go.
http://cgi.ebay.com/ebaymotors/TOYOTA-MR2-...sspagenameZWDVW
This post has been edited by lagos: Mar 8, 2008 - 1:11 AM
post Mar 8, 2008 - 1:17 AM
Fastbird
Joined Jun 25, '05
From Fort Wayne, IN
Wait.....there's a factory oil cooler? I sure as heck don't seem to have one on my car.
I've already got a oil filter sandwich adapter (there's one pictured in that ebay link) but the only 2 accessible ports are taken by the Oil Pressure and Temp Sensors.
Note* I seriously hope no one pays $280 for that ebay kit. That's a ripoff in a big way. A $40 sandwich adapter, a bar and plate cooler that's worth maybe $60 and some braided stainless line and a couple of fittings?? Not worth that price.
Now, I must ask. Why is using the drain side of the turbo to plumb in the cooler if using a scavenging pump a bad idea? Reason I ask is because it's a beautifully working system on my TT Corvette. I never see oil temps above 220 and that's AFTER railing on it for an hour. Normal driving I only see about 180-190 tops.
post Mar 8, 2008 - 1:26 AM
Yes you do. Its right under your oil filter. Its cooled by engine coolant.
Yeah, its just meant to give you an idea of what kind of setup you should look into .
Because the oil return line from the turbo should be as free flowing as possible with no restriction and assisted by gravity. You run a risk of blowing your turbo if you install an oil cooler on there.
post Mar 8, 2008 - 1:41 AM
Fastbird
Joined Jun 25, '05
From Fort Wayne, IN
Hmmm.........I haven't seen any type of fitting under my oil filter. I have been in there more than a couple of times and don't remember seeing anything.
As for the plumbing of a cooler on the drain side of the turbo.........you might be getting ahead of me here. I have already put thought to the fact that it could cause a backup which I know is b-a-d. But.....my way around that would be to put the scavenging pump in BEFORE the cooler, so that the scavenging pump is pulling off of the turbo and pushing through the cooler. I think that would be no more restrictive than the stock drain line and would provide the best results of installing a cooler.
post Mar 8, 2008 - 1:48 AM
Its the actual aluminum assembly that you screw your oil filter onto is your oil cooler. If you look at it closely, you'll see coolant lines running to it.
The oil cooler, fittings, lines, etc... would be a restriction over at big free flowing factory return line... with or without a pump. The best way to do it is to add a sandwich adapter to your oil filter.
This post has been edited by lagos: Mar 8, 2008 - 1:50 AM
post Mar 8, 2008 - 2:23 PM
phattyduck
Joined Dec 5, '05
From LA, CA
Similar to what the other guys have said, you need a sandwich adapter that has both oil cooler inlet and outlet ports and sensor ports (for your gauge). Ideally, you would also want a thermostat to avoid over-cooling your oil.
-Charlie
2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid
1988 Camry Alltrac LE - BEAMS swap started
post Mar 8, 2008 - 3:20 PM
Fastbird
Joined Jun 25, '05
From Fort Wayne, IN
Here's my question then: Has anyone tried using a scavenging pump and plumbing the cooler on the drain side? From my perspective, that's the side that needs the cooler and that's where the greatest impact can be made. I know that a lot of the custom turbo guys I've worked with on the V8 stuff use the setup exactly like I'm describing. I guess I'm just not understanding why it wouldn't work the same way on the factory type stuff.
post Mar 8, 2008 - 4:57 PM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
did anyone ever think that there is no oil cooler on his 3sgte? maybe it was replaced with the sandwich plate for gauges.... now this is a really bad idea as you can see with the oil temps... why don't you post a pic of your oil setup now fastbird.... and if you have no oil cooler... how did they seal the fitting on the bottom of the water pump? just curious...
Breaking Axles...
post Mar 8, 2008 - 5:08 PM
Fastbird
Joined Jun 25, '05
From Fort Wayne, IN
Let's not jump to conclusions here. I will freely admit that though I've been in there a few times, I haven't payed attention to if the filter is sitting on a cooler or not.. The sandwich adapter I put on there to facilitate the gauge installation. I'm going to take a look in there tomorrow on my day off and see what's going on.
post Mar 8, 2008 - 9:41 PM
alltracman78
Joined Aug 9, '06
From Ma
While it's very possible to pull the stock cooler and fab something up, it's not too likely unless you specifically requested it or did it.
The coolant lines are dependent on the oil cooler. You can't just pull the cooler, you'd have 2 open lines.
post Mar 8, 2008 - 10:06 PM
pabel89
Joined Sep 28, '07
From new jersey
what oil cooler would be good for the 7afte?
post Mar 9, 2008 - 3:07 PM
phattyduck
Joined Dec 5, '05
From LA, CA
QUOTE(Fastbird @ Mar 8, 2008 - 1:20 PM) [snapback]650741[/snapback]
Unlike many of the other guys on this thread, I believe that a scavaging pump on the oil drain line would actually be better than the stock drain setup... That doesn't mean you should do it though. There are thousands of 3s-gte motors with perfectly working stock drain setups, and adding a pump that might fail seems like a bad idea to me.
You can get significanly more oil flow through a full-flow oil cooler without the expense and hassle of a pump if you use an oil cooler sandwich adapter or filter relocation adapter. You can even relocate the oil filter at the same time to get it out of the way of the manifold/turbo/downpipe to make oil changes easier.
-Charlie
post Mar 9, 2008 - 9:35 PM
Fastbird
Joined Jun 25, '05
From Fort Wayne, IN
PhattyDuck, thanks for the vote of confidence.
Everyone, I know it's going to be easiest to get a sandwich adapter to plumb an aftermarket oil cooler in. I completely realize this. But, I feel that it's defeating the purpose because that hot oil draining from the turbo is still going to head directly to the pan and heat everything up.
My point of wanting to plumb the cooler in between the turbo drain and pan is to cool the oil at the most immediate possible point. This way, it's cooler going into the pan, and less convective heating is seen.
post Mar 10, 2008 - 2:16 AM
phattyduck
Joined Dec 5, '05
From LA, CA
QUOTE(Fastbird @ Mar 9, 2008 - 7:35 PM) [snapback]651142[/snapback]
Very little oil goes through the turbo compared to the rest of the bearings in the motor. I still think you can get much more cooling from a block adapter. Either way, I would be curious to see your oil temp results.
-Charlie
post Mar 10, 2008 - 11:54 AM
Fastbird
Joined Jun 25, '05
From Fort Wayne, IN
Well, problem is that I just can't go with another block adapter. I already have one on there, and am not interested in even trying to fit another one on top. biggrin.gif
post Mar 10, 2008 - 12:57 PM
Buy a new one with a thermostat and enough ports to hook everything up.
post Mar 10, 2008 - 2:10 PM
Harold_Fastwaker
Joined Aug 8, '07
From United States
QUOTE(lagos @ Mar 10, 2008 - 1:57 PM) [snapback]651450[/snapback]
I am looking at buying this one. (link is just reference) Mocal 180 degree built in t-stat to hook up oil coolers.
http://www.racerpartswholesale.com/product...Sandwich_Plates
Instead of running a remote T-stat. Just means I wont be using an oil relocation unit. I dont want to even try running 4 hoses out of the oil filter location.
3 Pages V   1 2 3 >
Lo-Fi Version Time is now: September 12th, 2026 - 8:28 AM
