Mar 20, 2008 - 8:28 AM
Enthusiast Joined Jan 3, '08 From USA Currently Offline Reputation: 0 (0%) |
I'm trying to determine if I need any special tools to replace the timing belt on my 7afe.
I did a little digging and found the pdf's for the tech manual & they show a special tool when you remove the belt. Is it really needed? EDIT: It's called "SST" & it is pictured for the crankshaft pulley removal. Is this just a pulley puller? END EDIT Also, I'm assuming I need to get a new belt & idler pulley, a new valve cover gasket, and a new water pump/gasket. Did I miss anything? I'm assuming Toyota parts are the way to go, right? Sorry for all the questions, but I'm new to Celicas. Thanks! This post has been edited by Brightside: Mar 20, 2008 - 9:30 AM |
Mar 20, 2008 - 10:29 AM
![]() Enthusiast ![]() ![]() ![]() Joined Aug 21, '07 From Toronto Currently Offline Reputation: 1 (100%) |
I think you also need a timing gun...
-------------------- -Derick
![]() "In hoc signo vinces." In this sign thou shalt conquer." Gone but never forgotten.... |
Mar 20, 2008 - 11:15 AM
Enthusiast ![]() ![]() ![]() Joined May 1, '03 From Michigan Currently Offline Reputation: 0 (0%) |
For the pulley tool, a standard Harmonic Balancer Puller is all you need, along with a good high-torque impact wrench to remove the bolt that holds it on.
-------------------- Scott
West Michigan |
Mar 20, 2008 - 1:43 PM
QUOTE(scothaniel @ Mar 20, 2008 - 11:15 AM) [snapback]656012[/snapback] For the pulley tool, a standard Harmonic Balancer Puller is all you need, along with a good high-torque impact wrench to remove the bolt that holds it on. Good, thanks. I've got all those things + a timing light. Can you even adjust the timing at the distributor on these cars? I thought that was flashed onto the ecm & controlled by the crankshaft position sensor. I dunno. On a side note - the Toyota parts counter didn't have any of the parts I needed (timing belt kit, various gaskets, and the water pump) and their price was $250 HIGHER than Napa (I'll take my chances on a car with 200k on the clock). The water pump alone was $121 vs. $59. Yikes. This post has been edited by Brightside: Mar 20, 2008 - 1:45 PM |
Mar 20, 2008 - 2:25 PM
Nope, timing is still distributor based (at least on the 5S and 3S motors).
For Toyota parts at good prices, check with Greg @ Metro Toyota www.toyotapart.com or Jeff @ Champion Toyota http://www.toyotaworld.com. -------------------- Scott
West Michigan |
Mar 24, 2008 - 7:51 AM
How do I hold the crankshaft pulley still in order to break loose the crankshaft bolt? Is there some special tool or holder?
On a small block chevy, I've always crammed a screwdriver in there - that's not an option on the Toyota... |
Mar 24, 2008 - 10:38 AM
Thats where the high torque impact comes in!
West Michigan |
Mar 31, 2008 - 7:41 AM
QUOTE(scothaniel @ Mar 24, 2008 - 10:38 AM) [snapback]657280[/snapback] Thats where the high torque impact comes in! Apparently, mine doesn't have enough torque (like my 200k 7AFE - LOL!). I ended up making a tool this weekend. I welded two tabs onto a piece of 3/16" bar stock (at about 45* angles) and spaced them so that they would grip the webbing of the balancer. I left the bar stock long enough (about 20") so that the tool would brace itself against the garage floor as I turned the crankshaft bolt. Problem solved. The same tool worked great to re-install the bolt. Thanks for help - I drove the car to work this morning. This post has been edited by Brightside: Mar 31, 2008 - 7:42 AM |
Mar 31, 2008 - 12:53 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Aug 9, '06 From Ma Currently Offline Reputation: 1 (100%) |
QUOTE(scothaniel @ Mar 20, 2008 - 2:25 PM) [snapback]656076[/snapback] Nope, timing is still distributor based (at least on the 5S and 3S motors). Even though it has a dist, timing is still fixed, as long as it's a 96 ^ Because of OBDII [US spec]. -------------------- ![]() |
| Lo-Fi Version | Time is now: August 30th, 2026 - 7:25 PM |
