> Remote central locking & indicator switch problems
post Apr 5, 2008 - 1:09 AM
GT88
Joined Apr 4, '08
The remote central locking doesnt work. The remote flashes but the doors dont open/close. What's wrong?
Also when turning right the indicator switch doesnt flick back however when turning left it does. How do I go about fixing this?
Thanks
post Apr 5, 2008 - 4:03 AM
stevest202
Joined Oct 28, '07
From epworth uk
QUOTE(GT88 @ Apr 5, 2008 - 1:09 AM) [snapback]661550[/snapback]
Thanks
have you checked fuses for central locking the indicator has a notch sounds like one has broke its what catchs it making it turn off
post Apr 5, 2008 - 5:11 AM
GT88
Joined Apr 4, '08
QUOTE(stevest202 @ Apr 5, 2008 - 4:03 AM) [snapback]661565[/snapback]
Thanks
Ill check the fuse tomorrow morning. With the indicator notch, can anyone give me step by step instructions on how I change the broken notch?
This post has been edited by GT88: Apr 5, 2008 - 5:12 AM
post Apr 5, 2008 - 6:39 AM
stevest202
Joined Oct 28, '07
From epworth uk
its part of the whole unit they wear down i replaced my indicater arm and it solved it if find a scrapper and tryable give it a test and see if it returns
post Apr 6, 2008 - 1:02 AM
GT88
Joined Apr 4, '08
Do I have to remove the steering wheel in order to change the indicator arm? Or is there an easier method to change the indicator arm?
post Apr 6, 2008 - 4:27 AM
stevest202
Joined Oct 28, '07
From epworth uk
no wheel dont have to come off just take the upper and lower coul around steering colum and you will see screws at top and bottom of your indicator and wiper arm they fasten together around the colum
post Apr 6, 2008 - 11:10 AM
if one side doesn't flash, you have a bad bulb.
Lo-Fi Version Time is now: August 2nd, 2026 - 10:00 AM
