> IACV Cleaned, Bad Results After Cleaning....
post Apr 13, 2008 - 4:10 PM
Remy
Joined Jan 25, '06
From MN
Hey all, I'll try to make this short anyways after taking out the IACV and cleaning it I put everything back and installed the new TB gasket on my car after starting it up it now idles at 1900rpms, before it was 1100rpms I'm not sure what went wrong I though after cleaning it out your idle was suppose to be lower not higher ?? I installed everything correctly and I doubled checked everything. Any ideas on what could of happened ?? Or do I just have a bad IACV and need to get a new one ?? Anyways let me know what you guys think it could be Thanks. frown.gif
post Apr 13, 2008 - 4:39 PM
it is now stuck worse than before. You should try to get another one.
post Apr 13, 2008 - 6:01 PM
Remy
Joined Jan 25, '06
From MN
I was hoping I didn't have to get another one they go for $100 new kindasad.gif I'll see if I can source out another one to see if thats the problem Thanks Bat !! thumbsup.gif
post Apr 13, 2008 - 7:49 PM
xs94st
Joined Aug 11, '07
From Corona, CA
quick question: where is the iacv on the ST?
Pandelica 2.0 in progress.
post Apr 13, 2008 - 9:19 PM
Remy
Joined Jan 25, '06
From MN
QUOTE(xs94st @ Apr 13, 2008 - 7:49 PM) [snapback]664238[/snapback]
On the bottom of the throttle body. You have to take the TB off to get to it.
post Apr 13, 2008 - 10:14 PM
Celicav
From Virginia
QUOTE(Remy @ Apr 13, 2008 - 4:01 PM) [snapback]664223[/snapback]
You can't swing $100? Use a credit car if you have to.
post Apr 13, 2008 - 10:52 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
QUOTE(Celicav @ Apr 14, 2008 - 3:14 AM) [snapback]664273[/snapback]
some ppl are in a bind. like i am atm. $100 is a lot for an 18 yr old
post Apr 13, 2008 - 11:04 PM
Celicav
From Virginia
QUOTE(stephen_lee @ Apr 13, 2008 - 8:52 PM) [snapback]664280[/snapback]
Yeah, I sometimes forget what it was like back in the teen and college days when $100 was a lot. And I should remember that many on this site are in this age group. Sorry, I am just an old 31-yr-old married guy and $100 is not a lot these days, esp. with a mortgage, car payments, bills, entertainment, etc. Oh to be young, innocent, and broke again, like in high school and college.
post Apr 14, 2008 - 2:11 AM
xs94st
Joined Aug 11, '07
From Corona, CA
a hundred bucks is sorta like 1000 bucks for me nowadays lol. thanks remy for pointin out where its located
post Apr 14, 2008 - 7:23 AM
make sure theres no air leaks. spray around where you worked with brake cleaner, it'll change its idle some if there is a leak when the cleaner gets sucked in.
post Apr 14, 2008 - 4:34 PM
Remy
Joined Jan 25, '06
From MN
QUOTE(Celicav @ Apr 13, 2008 - 10:14 PM) [snapback]664273[/snapback]
I can just that I don't plan on keeping this motor that long, I just bought a new IACV anways and I don't make $100 dollars an hour or else I would be rolling in a MKIV Supra. smile.gif
QUOTE(Bitter @ Apr 14, 2008 - 7:23 AM) [snapback]664364[/snapback]
I think u just hit it right on the nail Bitter I believe theirs a leak on one of the hose I didn't see, its because it was leaking from the intake side so it wasn't visible to me a small leak. frown.gif
Thanks for all the help guys I'll see if I can get that leak fixed today and install my new IACV when it comes. thumbsup.gif
post Apr 14, 2008 - 8:30 PM
QUOTE(Remy @ Apr 14, 2008 - 4:34 PM) [snapback]664531[/snapback]
Lo-Fi Version Time is now: September 14th, 2026 - 11:50 AM
