> Emissions
post Apr 21, 2008 - 8:42 PM
Dtuner17
Joined Apr 16, '08
From CT
i got a 97 gt celica and im planning to put on an exhaust headers but a friend mine says i might fail an emissions test if i do this. anyone know anything about this?
This post has been edited by Dtuner17: Apr 21, 2008 - 8:49 PM
post Apr 21, 2008 - 10:57 PM
xredjokerx
Joined Apr 18, '08
From Oakland, bay area, California
you most likely will, since the stock internals are made to fit emissions test. However, it also depends on the state youre in. maybe you should check CT emission regulations before you do anything, especially since there are some things you can do to get around it..
i forgot which state it was in, but in that state, you only need to smog if you drive over a certain limit a year, in which they just switched the odometer and bam, they didnt need to smog. shh =)
post Apr 22, 2008 - 3:54 PM
Dtuner17
Joined Apr 16, '08
From CT
here are the regulations for my state:
Parameters of the Inspection
The emissions inspection includes the following tests:
Gas cap leakage
An onboard diagnostics exam for vehicles 1996 or newer
An acceleration exam for vehicles 1995 or older
An idling test for some vehicles
will i be able to pass it with exhaust headers
This post has been edited by Dtuner17: Apr 22, 2008 - 3:55 PM
post Apr 22, 2008 - 4:09 PM
DEATH
Joined Dec 19, '07
From tx
Yes as long as they don't leak and you install an aftermarket Cat in replacement of the stock primary cat and route your o2 sensor(s) in the same spot relative to the cat as was the stock setup.
You may have a visual test you might fail tho - depends on the local laws.
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
post Apr 22, 2008 - 4:15 PM
Dtuner17
Joined Apr 16, '08
From CT
ok thanks for the help
Lo-Fi Version Time is now: May 10th, 2026 - 2:52 PM
