> Possible brake issue
post May 6, 2008 - 1:08 PM
Drew-887
Joined Jan 5, '05
From Upper Darby, PA(5 min away from Philly)
Hi everyone im worried that my front caliper might have issues. I have alot of brake dust just from the one driver side brake caliper and sometimes it makes this squeaking noise. Braking still works fine but I noticed that the car sometime does not move while in sitting in neutral. Also my the rotor looks alot more worn out on the drivers side than on the other side. What do you think is wrong and if there is can it be an easy fix?
post May 6, 2008 - 10:25 PM
alltracman78
Joined Aug 9, '06
From Ma
It sounds like your caliper or caliper slide pins are frozen.
Depending how bad it could be easy, or not.
Either it's repairable or not.
To find out, take it apart and see if the piston and slide pins move with a bit of persuasion.
If not, you need to replace it.
Lo-Fi Version Time is now: August 31st, 2026 - 1:34 PM
