> Transmission question
post May 21, 2008 - 8:42 PM
Justen
Joined May 17, '08
From North Liberty, IN
I have a 94 st, i want to swap in a 3sgte. i was going to just use a 5sfe trans but i was wondering if the 5sfe trans out of a camary or earlier model celicas would wok and if what the transmission code or name is.
post May 21, 2008 - 8:56 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
Yes will work. S54 The early ones are S53.
94 Celica gt white (sold)
post May 21, 2008 - 9:02 PM
Justen
Joined May 17, '08
so 5gen celica has s53 and 6gen has s54? is there any differences? which does the camary have? is the a difference between the 5sfe cluctch and the 3sgte clutch as far as splines and bolting it to the flywheel?
post May 21, 2008 - 9:05 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
You can either mix and match clutch compnents, but do what I did and contact Doc Tweak and order a cutom clutch. It will run you around 400, but I'm sure it will be well worth it. I'm not quite sure about the 5sfe camry tranny, but I guess it depends on the year. I'll put it this way, if the 5 speed manual tranny that bolts onto any 5sfe motor, it will bolt right onto the 3s motor with a custom clutch or mix and matched components.
Lo-Fi Version Time is now: May 18th, 2026 - 8:26 AM
