Jul 8, 2008 - 11:17 AM
![]() Enthusiast Joined Jul 12, '06 From Minnesota Currently Offline Reputation: 0 (0%) |
95 GT convertible (5SFE), 141k miles, 5 spd manual, all factory except SRI. Car runs like a top except for a code 71 (CA emissions, EGR failure.) Not that I think it's related.
I had the clutch replaced last year, about 10k miles ago. Now my clutch has been requiring more and more travel. Pedal height and freeplay are set correctly according to factory specs, but now I have to pull the top carpet back and put the clutch pedal all the way to the floor to change gears. As soon as I take it any distance off the floor, the car starts to roll. Sometimes after it warms up it doesn't want to shift into gear (esp. into 1st) or grinds a bit (esp. into 4th.) Yesterday I thought I was going to be stranded but after forcing it into gear and getting it home I left it sitting for an hour or two and have had no problems since (other than still needing to put the pedal to the floor.) I'm guessing something is wearing out. Any ideas? I replaced the slave cylinder last year when I had the clutch replaced as well. Thank you in advance for your input! --Rick |
Jul 8, 2008 - 12:53 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 14, '03 From Long Island, N.Y. Currently Offline Reputation: 1 (100%) |
i was gonna guess slave cylinder as well. could there possibly be a leak?
Jul 8, 2008 - 1:00 PM
Well, I looked at the cylinder itself and saw no evidence of leakage. If it was a leak, why would it get worse and better again? I haven't tried bleeding it yet, but that's one thing I'll try tonight.
i was gonna guess slave cylinder as well. could there possibly be a leak? |
Jul 8, 2008 - 3:55 PM
Enthusiast ![]() ![]() ![]() Joined Nov 14, '06 From Northampton, UK Currently Offline Reputation: 5 (100%) |
You can't tell by looking and it could be ither master or slave. There is a rubber washer on a plunger - the cylinder is a bit like a syringe. When the rubber washer starts to wear out, fluid can move from one side of the syringe to the other even when the plunger doesn't move.
A good test for this is if you push your clutch to the floor really quickly then the biting point is at a different place than if you keep the clutch dipped for much longer. When it really starts to wear out, you may find that the clutch won't disengale or re-engages when the pedal is depressed. -------------------- Davey
Items for sale |
Jul 8, 2008 - 4:21 PM
You can't tell by looking and it could be ither master or slave. There is a rubber washer on a plunger - the cylinder is a bit like a syringe. When the rubber washer starts to wear out, fluid can move from one side of the syringe to the other even when the plunger doesn't move. A good test for this is if you push your clutch to the floor really quickly then the biting point is at a different place than if you keep the clutch dipped for much longer. When it really starts to wear out, you may find that the clutch won't disengale or re-engages when the pedal is depressed. OK, so what other things can cause this problem? A worn busing or anything? Or if I'm not sure should I just replace the master (since I've never replaced it before) and then the slave (since it was a rebuilt)? |
Jul 8, 2008 - 5:31 PM
I had the clutch master cyl replaced in my SS-I at 179,000 KMs , The pedal was starting to play up at first the pedal would come back half way and bounce back violently leaving people to think I was bad driver... Then the pedal would get stuck to the floor and let the clutch engage I'd have to pry it out with my toes and hog neutral until the very moment of takeoff as holding the pedal in longer than a second would cause it to get stuck. The job costed about NZ$300 ..
-------------------- Mike W
Jul 9, 2008 - 8:20 AM
A closer look at the master clutch clyinder shows that the fluid level was a little low. I flushed the line and it was BLACK! Performance has improved and I'll watch the fluid level. Thanks everyone for the help!
| Lo-Fi Version | Time is now: August 4th, 2026 - 10:08 AM |
