> Clutch replacing and a light flywheel
post Jul 9, 2008 - 2:55 PM
Prodigy515
Joined Jun 20, '08
From c-port
After driving my celica over two weeks, I have realized I am definatly not going to be able to hold out on the stock clutch for any longer, I have not been touching the clutch...rev matching FTW.....I was hoping to have the E153 ready to go, but it looks like I am just going to throw in a stock disk. I have the E153, stage 4 clutch and lightweight flywheel...but I am waiting on some other parts to go with it so I would rather get a temporary clutch then try to rush replacing the tranny. Me and my friend are going to replace the clutch this friday after work, I figure while I am in there I will also put the lightweight flywheel in, then have it resurfaced when I get the E153 together.
A quick picture...
I will take some pictures of the install this friday...hopefully we will get started by 7pm
-Prodigy515
4th Gen 3SGTE Swapped Celica
http://www.phoenixtuning.com
post Jul 13, 2008 - 9:12 AM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
I would just wait out for all the parts. If its lasted till now it will last a little longer. Clutch replacing is not easy and should only be done right once not twice.
post Jul 14, 2008 - 12:43 AM
Harold_Fastwaker
Joined Aug 8, '07
From United States
QUOTE (soulshadow @ Jul 13, 2008 - 10:12 AM) *
I have done it in 3.5 hours on my drive way. I have a done a civic just the same as well.
post Jul 14, 2008 - 1:58 PM
Prodigy515
Joined Jun 20, '08
From c-port
Finished the clutch job, my friend and I got a late start on it but got it finished up by about 1:30 in the morning. I was hoping to hold out for ST205 mounts witch should be here in a week or two....but the clutch would slip with anything over about 20% throttle.
Picture of the clutch that made a 300 mile drive + three weeks of daily driving...a little suprised it made it as long as it did....
stock flywheel
Here is a picture of the tranny dropped down...
To clarify everything, I have an E153 transmission, stage 4 clutch for E153, and a light weight flywheel for the 3sgte. Since this was a temprorary fix I got a clutch made locally with a 5sfe disc and 3sgte hub. The 3sgte flywheel worked fine all I did was use different flywheel bolts. Also used the stage 4 pressure plate. All in my stock GT tranny.
3sgte flywheel
All in all I was very impressed with the feel of the pedal now, it is quite firm, and the flywheel is amazing. The celica will easily chirp going into 2nd gear, and trying to take of from a stop was interesting the first couple times I drove it. It would either stall or spin...luckily I have got the hang of it before spinning the tires next to any police.
I am on edge waiting for my ST205 mounts and one other thing for the E153, hope to have it in the celica before to long...
This post has been edited by Prodigy515: Jul 14, 2008 - 1:59 PM
-Prodigy515
post Jul 17, 2008 - 8:50 AM
Prodigy515
Joined Jun 20, '08
From c-port
UPDATE:
ST205 mounts from japan are going to be here in about a week, and then my pride and joy comes in two weeks.....the Quaife ATB differential
-Prodigy515
post Jul 20, 2008 - 1:44 PM
hardcoreproducer
Joined Jul 2, '08
From Midlands, UK
post Jul 20, 2008 - 3:23 PM
Renegade
Joined Jul 20, '08
From Columbus, Indiana
just wondering if when i change my clutch will getting a light weight flywheel affect the balance or anything with my engine?
post Jul 21, 2008 - 12:29 AM
Harold_Fastwaker
Joined Aug 8, '07
From United States
QUOTE (Renegade @ Jul 20, 2008 - 4:23 PM) *
The balance? No, this is not a rotary. The lighter flywheel will allow the car to rev quicker. Just bolt it on along with your new clutch/pressure plate and you are good to go.
Lo-Fi Version Time is now: August 27th, 2026 - 3:30 PM
