Jul 11, 2008 - 3:15 PM
Enthusiast ![]() Joined Jan 8, '08 From Sweden Currently Offline Reputation: 0 (0%) |
So I want to connect my alarm to my driver side window so that the window roll up when i lock the doors. My alarm has an output that generates 0.65V for about 13 seconds. So that is all good, exept that it is ONLY 0.65V.
I was going to connect it to a relay (spelling?) but the relay triggers first at 9V... I know how to use my multimeter so I'm pretty sure about the voltage (also tryed the relay but it is silent, should klick). So, anyone got any ideas what to do? //Johan |
Jul 12, 2008 - 5:00 AM
Hi i have done the same window roll up set up your trying to do.
If your trying to hook up the roll up module to the locking signal on your remote, it will not work. Because the signal from your alarm is only a pulse (maybe half a second of signal) and that is not enough to roll up the entire window. What you would need to do is hook up the roll up module to your "armed when ground" wire on your alarm. The "ground when armed" wire is usually the same wire you use for kill start. good luck. |
Jul 14, 2008 - 2:39 AM
Hi i have done the same window roll up set up your trying to do. If your trying to hook up the roll up module to the locking signal on your remote, it will not work. Because the signal from your alarm is only a pulse (maybe half a second of signal) and that is not enough to roll up the entire window. What you would need to do is hook up the roll up module to your "armed when ground" wire on your alarm. The "ground when armed" wire is usually the same wire you use for kill start. good luck. As I already said: My alarm has an output that generates 0.65V for about 13 seconds. So no, I'm not trying to connect my window module to my locking signal. But tanks anyway. I think i must messure the output again, 0,65V does not sound right at all...somthing must be wrong... |
| Lo-Fi Version | Time is now: May 20th, 2026 - 11:15 AM |
