> 3sge jdm swap, ran into some rather odd problem
post Aug 4, 2008 - 10:39 PM
vile_v
Joined Jun 16, '07
From Vancouver, Canada
Hey Guys, I'm not sure if this should be in the off-topic or in engine maintenance. I started this topic in engine cause it partly related to the 6 gen celica. I've been working on a 88 celica with a 3sge engine trying to gain some experience in swapping before i do my 95 celica.
The plan was to swap out the usdm block and internals for a jdm block and its internals because the usdm crankshaft was badly damaged. During this swap I've encountered a few differences, for example the pistons are different (jdm have wedge top as where usdm have a flat top). The one difference that I'm stuck on is the flywheel. The usdm flywheel (11-1/4") is smaller than jdm flywheel (12") and the hole for mounting are slightly off. The jdm flywheel is actually a 5sfe flywheel. I know that both celica uses The S53 tranny, so is there anyway to make a hybrid flywheel? or some sort of setup that would work. * usdm starter is in a difference place compared to the 5sfe starter
I need the size of a usdm flywheel with the mounting holes of a 5sfe flywheel.
If you guys have any tips or suggestions that would be awesome, THANKS!
post Aug 5, 2008 - 10:47 AM
use the flywheel for the specific crank. you dont want sizing issues. in alot of toyota cases the flywheels are a little different but the same clutch will fit and work. as for the pistons being flat or wedged, that to change the compression
post Aug 5, 2008 - 3:08 PM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
I can make you any type of hybrid clutch you need, just let me know what flywheel you're using and which transmission.
-Doc
Click here to see my swaps
drtweak@phoenixtuning.com
post Aug 5, 2008 - 7:22 PM
vile_v
Joined Jun 16, '07
QUOTE (Smaay @ Aug 5, 2008 - 4:47 PM) *
The only problem to that is if we use the jdm flywheel (5sfe) the starter is not going to fit.
QUOTE (Dr_Tweak @ Aug 5, 2008 - 9:08 PM) *
-Doc
Thanks Doc! let me ask the other guys if that's the road we are going to take.
This post has been edited by vile_v: Aug 5, 2008 - 7:23 PM
Lo-Fi Version Time is now: August 31st, 2026 - 5:04 PM
