> noise near left rear wheel
post Nov 12, 2008 - 2:58 AM
BeefyT
Joined Feb 19, '08
From Anaheim,CA
There is a weird noise coming from the left rear wheel....the only way i can describe the noise is it sounds like a cricket continuously chirping....does anybody know what it could be?
lol
post Nov 12, 2008 - 10:53 AM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
an actual cricket! no, how bout a seized bearing, that keeps making your rotors warp and rub against your pads when you drive
post Nov 12, 2008 - 11:33 AM
BeefyT
Joined Feb 19, '08
From Anaheim,CA
is that an easy fix...how much would u say it would cost to fix?
lol
post Nov 12, 2008 - 1:55 PM
LewFX
Joined Jan 28, '05
$150 for the hub and wheel bearing, trimming rotors is $20 a piece, should do both sides..labor depends where you take it, i could do it for $40
post Nov 12, 2008 - 4:17 PM
BeefyT
Joined Feb 19, '08
From Anaheim,CA
QUOTE (LewFX @ Nov 12, 2008 - 1:55 PM) *
but are u sure that it is the problem...i hear the noise even when im idle
lol
post Nov 12, 2008 - 4:50 PM
LewFX
Joined Jan 28, '05
you never said that! maybe something is loose. tighten up the sway bar bushing, end links, brakes, etc
post Nov 12, 2008 - 4:54 PM
BeefyT
Joined Feb 19, '08
From Anaheim,CA
QUOTE (LewFX @ Nov 12, 2008 - 4:50 PM) *
oops lol...thanks man ill check it
lol
post Nov 12, 2008 - 8:40 PM
axelrduvirage
Joined Feb 8, '06
From Nova Scotia, Canada
can you hear it from outside the car?
- maybe a loose suspension part, broken spring
if its coming from inside
- empty your hatch. take everything out and repack it. could be a loose cover, spare, jack. could be an improperly latched rear seat (actually heard that one once or twice).
my 0,02$
post Nov 13, 2008 - 1:38 PM
oscar_1987
Joined Nov 13, '08
From NC
blown strut maybe?
post Nov 14, 2008 - 11:26 AM
jimmykay
Joined Jul 14, '08
From St. Louis
does it make the noise when you're standing still or only moving?
If its only when you're moving, I'd start checking your brakes too, possibly its a dust shield or something rubbing.
'99 Celica GT - Sold
'11 Mazdaspeed3
post Nov 15, 2008 - 3:08 AM
freddymak18
Joined Sep 22, '08
From markham
I have the exact same problem! no clue what it is, mechanically retarded. Thought I'd just let you know you're not alone... smile.gif Going to go with LEWFX on this and try to tighten everything up.
Lo-Fi Version Time is now: August 27th, 2026 - 6:51 PM
