Nov 14, 2008 - 7:29 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 2, '05 From Guam Currently Offline Reputation: 15 (100%) |
I have a 5sfe auto trans celica, but I want to convert it to manual trans. Will a 3sfe tranny mount up right to our 5sfe? Is it direct bolt on, will I need new axles, will modifications like drilling be needed, will it work at all?
Nov 17, 2008 - 7:45 AM
Can I take everything I need from the 3sfe like shifter cable, clutch resevoir, all the little things and transfer them over? Or is it only the transmission itself?
Between the two checklist I found, what is what and what is needed really and from what model car specifically. Here is the checklist from Doc *much shorter*. Manual tranny Flywheel and bolts Clutch kit (and pressure plate bolts) Driver's side mount for manual Shifter assembly Shifter cables Clutch pedal assembly Brake pedal (or grind down your stock one) Clutch master cylinder Clutch slave cylinder (if not included with tranny) Clutch lines Manual ECU or wire in resistor box for the auto ECU Checklist from Sev408 -Transmission -Shifter -Shift Cables -Flywheel -Clutch Master cylinder -Slave cylinder -New clutch -Clutch metal fluid lines -Rubber clutch line -Flywheel bolts -Pressure plate bolts -Clutch pedal assembly -Manual brake pedal (just the pedal because John told me you dont need the whole assembly) -Tranny fluid -Brake fluid for clutch -Manual Transmission Drivers Side Mount -Starter Relay for Manual -2 bolts for Trans- 12 by 1.25 (1 is 65mm other is 75mm) -Manual ECU (I bought it because I dont want to have a constant check engine light) -Gear Greace This post has been edited by trdproven: Nov 17, 2008 - 8:35 AM -------------------- 94 Celica GT
| Lo-Fi Version | Time is now: August 28th, 2026 - 6:31 AM |
