> What is LSD?
post Dec 4, 2008 - 10:51 PM
silverceli09
Joined Nov 13, '08
From Indiana
what are you referring to when you talk about installing LSD in your tranny? what is it? confused.gif
Celica Or Die, check out http://www.redlinemotive.com!
post Dec 4, 2008 - 10:56 PM
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
It's a drug.
post Dec 4, 2008 - 10:58 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
LSD= Greatness
LSD means Limited Slip Differential.
For example the stock 5sfe Celica GT transmission utilizes the S54 OPEN Differential trans. No LSD.
Eventhough if you take a peak inside the diff where the axles pop into there is a bar running through the middle of it just like the E153 VLSD trans, the s54 isnt lsd.
VLSD what I've got means Viscous Limited Slip Differential. The difference between mine is that the Viscous uses liquids to get the LSD to work, which means it is less aggressive compared to a clutch type lsd.
Basically when one wheel spins the other picks up the slack.
94 Celica gt white (sold)
post Dec 4, 2008 - 10:59 PM
silverceli09
Joined Nov 13, '08
From Indiana
QUOTE (GotToyota @ Dec 4, 2008 - 10:56 PM) *
It's a drug.
how did i know someone was gonna say that? lol...but seriously, when talking transmissions, what is it?
post Dec 4, 2008 - 11:00 PM
samir0189
Joined Mar 8, '08
From Orlando, Florida
limited slip differential. It prevents "one wheel" power. In a tranny without lsd, if you spin the wheels, only one side will really do most the spinning. LSD detects wheel spin and puts power to both drive wheels, instead of one. biggrin.gif
My F/S Thread!
Ferdi says (11:29)
post Dec 4, 2008 - 11:07 PM
silverceli09
Joined Nov 13, '08
From Indiana
post Dec 4, 2008 - 11:13 PM
97celiman
Joined May 22, '08
From dallas texas
yes but is it possible to "install" LSD in a transmission or does it pretty much have to come with it (the trans)
also is the e153 w/lsd bolt up to 5s?
post Dec 4, 2008 - 11:23 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
You can by a differential to put inside the trans. Easy IMO. Yes the e153 bolts on, but you'll need hybrid axles to run it on our cars.
post Dec 4, 2008 - 11:30 PM
97celiman
Joined May 22, '08
From dallas texas
so you could have a s54 with lsd...has anyone with a 5sfte done this or have lsd?
This post has been edited by 97celiman: Dec 4, 2008 - 11:54 PM
post Dec 4, 2008 - 11:45 PM
Rusty
Joined Nov 5, '07
From New Zealand
came in standard SS-III (98+ or earlier version aswell?) gearbox, TRD also make a machnical one which is available for non SS suspension (helycal L.S.D.)
post Dec 4, 2008 - 11:55 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
I forgot who, but someone used the mr2 spyder's differential in their s54.
post Dec 5, 2008 - 4:48 AM
bslik
Joined Oct 10, '07
From Sunrise Florida
i was told that my car has lsd when i bought it n i thought he was mistaking. is there any way i could make sure? do i have to go drive through a lake and see if i hydroplane? confused.gif
This post has been edited by bslik: Dec 5, 2008 - 4:49 AM
post Dec 5, 2008 - 5:39 AM
whatthe
Joined Aug 13, '08
From Australia
QUOTE (GotToyota @ Dec 5, 2008 - 2:56 PM) *
What does the picture have to refer to the drug?
post Dec 5, 2008 - 11:01 AM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
QUOTE (bslik @ Dec 5, 2008 - 3:48 AM) *
hydroplaning has nothing to do with lsd. One way you can tell is put your car in neutral and jack your car up and have both tires off the ground. Spin one tire and see if the other tire spins the same direction as the one you are spining. If it spins the same way it has lsd. If it spins opposite it doesnt.
post Dec 5, 2008 - 11:03 AM
^ that does not always hold true
post Dec 5, 2008 - 11:06 AM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
Yeah I know, but its one way you can kind of tell.
post Dec 5, 2008 - 11:23 AM
It's totally unreliable. That's no way to determine whether you have LSD or not.
post Dec 5, 2008 - 11:27 AM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
okay fine. Pull your axles and peak in there. With the stock s54 trans you will see a bar runnning through the diff. That means you don't have lsd. If you peak through it and the bar is removed and you can totally see through it, you might have an after market lsd. If you have an e153 trans and you see a bar running through it you have lsd. VLSD.
post Dec 5, 2008 - 5:17 PM
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
QUOTE (whatthe @ Dec 5, 2008 - 4:39 AM) *
It doesn't, it just shows how I feel about such a common-sense question being asked.
post Dec 6, 2008 - 7:21 AM
xredjokerx
Joined Apr 18, '08
From Oakland, bay area, California
http://www.jdmuniverse.com/forums/nissan-i...lsd-vs-lsd.html
Lo-Fi Version Time is now: September 14th, 2026 - 4:56 AM
