Dec 21, 2008 - 5:50 PM
![]() Enthusiast ![]() ![]() ![]() Joined Mar 3, '07 From Sunny Florida Currently Offline Reputation: 18 (91%) |
First off its 31 before zero here [windchill]
So..went to go start my car started right up besides some minor hesitiation and a bit of weird starting noises. Let it run for 20 mins..thought it'd be super warm and toasty in the car. Not at all, Its cold as it is outside almost. I pop the hood and coolant lines are dead dead and filled with soild ice ! Should i let it run untill the engine warms up enough to thaw it out or what.. This is a new one for me. =[ Its in the garage right now with the heaters on...Hope that helps a bit. ~prays ~ =/ -------------------- ![]() |
Dec 21, 2008 - 6:03 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 6, '05 From PA Currently Offline Reputation: 4 (100%) |
I'd probably leave it in the garage for a while, if you run the car with blocked coolant lines you run the risk of overheating the engine... are you sure your coolant is at the right mixture?
Dec 21, 2008 - 6:24 PM
Yeah, in the garage w/ heaters all up on it should help, if your running a 50/50 mix its only good down to -34 (aprox), giving where you live and how cold it tends to get you might consider running a 70/30 mix during winter (good aprox -84 f - 276 f). But if it really gets that cold there try to garage and heat you vehicles when left overnight.
Dec 21, 2008 - 6:28 PM
No..I got a bit low on coolant like 2 weeks ago and toped her off with water so..its prolly like 60/40 antifreeze < water.
So i know its my own dumbass fault just trying to unthaw her now. And yes i will def be garaging the DD from now on. -------------------- ![]() |
Dec 21, 2008 - 6:32 PM
Yeah that would def affect the freezing point.
Dec 21, 2008 - 6:53 PM
Yea I know =[
But im hoping it didnt crack the block or mess up anything else. theres an upgrade waitiong to happen if i did though..So ...Always a silver lining. -------------------- ![]() |
Dec 21, 2008 - 7:39 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 28, '07 From Banland Currently Offline Reputation: 1 (100%) |
thats the prob...mighta cracked the water jacket...
Dec 21, 2008 - 8:08 PM
hopefully everything is fine....hate when things come up before your totally ready. Been happening to me recently and im kinda getting tired of it.
Dec 21, 2008 - 8:14 PM
hopefully everything is fine....hate when things come up before your totally ready. Been happening to me recently and im kinda getting tired of it. ya no lie man, When it rains it pours.. But it also can't rain forever. In any case... This is for my echo = 1zzfe So if it is a busted water jacket. The 2zz will be going in early. Me and dr teak have already discussed this one so... Heres hoping. -------------------- ![]() |
Dec 21, 2008 - 10:25 PM
Enthusiast ![]() ![]() ![]() Joined Sep 28, '07 From Toronto, ON Currently Offline Reputation: 5 (100%) |
Leave it in a place even if it just 3 walls like a car tent or something, and connect it up with a block heater.
you should see over in Calgary, AB; the other day it was -37 WITHOUT windchill |
Dec 22, 2008 - 12:51 AM
and i think positive 30 is cold as hell hahahahha
Dec 22, 2008 - 9:30 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 18, '08 From Houston Currently Offline Reputation: 7 (100%) |
First off its 31 before zero here [windchill] I pop the hood and coolant lines are dead dead and filled with soild ice ! This; good sir; is why Santa Claws (in the same arctic temperature you're at) himself drives a sled powered by reindeer instead of an engine driven snowmobile/hovercraft-jet. Granted the sled was made by Toyota, but still... no engine. My advice is to move. -------------------- QUOTE (presure2 @ Nov 6, 2010 - 6:16 AM) Via FB: fcuking awsome!!! D-man FTW! Damn D-Man - most impressive. D-Man's post should be a sticky LOL, oh boy, you can always count on D-Man for ridiculously hilarious posts. |
Dec 25, 2008 - 1:03 AM
Update:
I cranked the garage up to about 90 degrees for a day..let the slush and whatnot drain out of the rad and motor. Refilled the cooling system with new coolant, Also found a freeze plug that poped out about a half inch. So after all that car is running good again, .has heat and seemed to be good.Untill i examined the drained coolant.The coolant is about a year old, But its very dark..Like very dark brown..I let a gallon of it sit in the garage for a day..The bottom half was darker than the top half.Oil in the coolant ?..or just sludge from the motor ? -And ya i plan on moving south asap, So..Im workin on it. -------------------- ![]() |
Dec 25, 2008 - 2:04 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jul 12, '08 Currently Offline Reputation: 5 (100%) |
sludge i guess
Dec 25, 2008 - 2:42 AM
sludge i guess Yea im hoping so..Oil floats the to the top of coolant if i remember right so.. Still don't like it though =/ -------------------- ![]() |
Dec 25, 2008 - 4:40 AM
Enthusiast ![]() Joined Jan 8, '08 From Sweden Currently Offline Reputation: 0 (0%) |
If you got oil in the water...shouldn't it be water in the oil then? so my tips is to check the oil and see if the oil is brown(ish). But it think it is just sludge...
How's the freeze plug? Does is leak any fluid? Good luck, hope you can fix it, I really hate when the engine freezes...my old Opel did that a couple of times. |
Dec 25, 2008 - 3:59 PM
If you got oil in the water...shouldn't it be water in the oil then? so my tips is to check the oil and see if the oil is brown(ish). But it think it is just sludge... How's the freeze plug? Does is leak any fluid? Good luck, hope you can fix it, I really hate when the engine freezes...my old Opel did that a couple of times. I did some research. if you have a blown HG [what i was fearing]..Its possible for the coolant to have oil in it and not have collant in the oil. and vice versa...So no according to the info on the net you can have one w/o the other.The freeze plug was leaking collant. But after i hammered it back in, It was fine. No leaks..Thank god. We're gonna get a warm front here in indiana..temp is going to be in the mid 50's saturday..So im going to drain and flush the entire rad and motor and refill the cooling system again..See if that helps. ~ fingers crossed ~ -------------------- ![]() |
Dec 26, 2008 - 9:43 AM
I did some research. if you have a blown HG [what i was fearing]..Its possible for the coolant to have oil in it and not have collant in the oil. and vice versa...So no according to the info on the net you can have one w/o the other. Cool, never heared about. Good Luck... |
| Lo-Fi Version | Time is now: September 1st, 2026 - 7:57 AM |
