> Oil Pan Resealing Has anyone done this? how hard?, Oil Pan 2.2L Coupe
post Jan 27, 2009 - 2:44 PM
tt966g
Joined Nov 5, '08
From Tampa, FL
Need to reseal oil pan and got technical specs on how to do it, but was wanting to get input on some folks that have done this themselfs? 2.2L coupe
post Jan 27, 2009 - 6:28 PM
1bwilson
Joined Aug 30, '02
From Maryland
The hardest part about is getting the pan off really. Drain it and remove all bolts around the outer parts of the pan, there are alot. Youll have issues with a few being behind the cross member. Once you have got it off use a razor or something alike to remove the old gasket and then use rtv to reseal the pan back on. Once its dry or had some time to set you can wipe or cut the extra rtv off the sides of the pan. Its messy, a pain in the butt at times but not very hard.
Member of Team 5sfTe
post Jan 29, 2009 - 8:37 PM
use toyota FIPG instead of RTV
Lo-Fi Version Time is now: May 24th, 2026 - 9:17 PM
