> steering wheel removal, how do i remove it?
post Oct 8, 2003 - 7:03 PM
soldier4life
Joined May 1, '03
From san diego, california
i just got a new steering wheel i want to put it in but i dunno how to take the stock one out...can someone help me out?
post Oct 8, 2003 - 8:45 PM
ToYCeLi8
Joined Mar 6, '03
From South Central Los Angeles and Long Beach, CA
Hey did you have to buy a hub for the steering wheel? I'm getting the tenzo version 5 s/w and i was told that for any after market steering wheel i you have to get the hub??
Is that true??
David
post Oct 8, 2003 - 11:40 PM
soldier4life
Joined May 1, '03
come on someone has got to know something
post Oct 9, 2003 - 12:28 AM
I'm pretty sure you need a hub. Also, you'll need to re-locate your cruise control if you have it. That's all that I know though. John and Doggy both have aftermarket wheels, and I'm sure that they can help. Just have patience. wink.gif
post Oct 9, 2003 - 12:32 AM
neophile
Joined Nov 8, '02
From New Zealand
okay, this is from memory so probably isn't too acurate, but it may help smile.gif
The first thing would be to find out if you have an airbag or not, since you'll need to disable it if you do (I don't have one, so i'm not sure on this, but i believe you disconnect the battery and wait 15 seconds or so before beginning work - I'm sure some one else can confirm this)
If you are airbag-less like me, then the first step is to remove the centre cover (the thing you press to make the horn work). On mine i pulled the top two corners towards me and it unclipped the top - the bottom part is a little more tricky, since if you get under your steering wheel and look up, you'll see a small hole with a screw in it - unscrewing this will release the bottom part of the centre cover and allow you to remove it.
You should now see a large bolt, I used the largest spanner I had and it just fitted it, and unscrewed this - note - this took quite a lot of effort, which I guess is a good thing smile.gif )
(if at this point you see 3 other screws that appear to holding the wheel on, remove these as well - i'm not sure if these screws were on the celica or corolla - stupid poor short-term memory smile.gif )
You should now be able to slide the steering wheel off by pulling it towards you - I believe the professionals use a steering wheel puller or something, but I just pulled it towards me - it has to be pulled evenly otherwise it will stay put, and feel like it is still bolted on - i spent about 5 minutes tugging at it with no luck, then, while adjusting my seat grabbed the wheel to pull myself forward and it slid of like it was a hot knife in butter smile.gif so i guess it's all in the technique . . .
Adding a new wheel should be the same process reversed, except i've heard some after-market wheels need a hub or something to fit on the toyota steering column thingy - once again i'm sure others will be able to provide more accurate or knowlegable info - but hopefully this is enough info to get you started - unless of course you have an airbag, then all of this was simply a good typing exercise for me biggrin.gif
post Oct 9, 2003 - 12:51 PM
soldier4life
Joined May 1, '03
i have airbags...well when i try to pull the cover off...it wouldn't come off...so anyone who has remove there steering wheel with airbags please help me out...thanks
post Oct 9, 2003 - 2:18 PM
celicakid84
From New Jersey
there is a little black panel on either side of the steering wheel, pop them off with a flat head screwdriver. That will reveal 2 screws on either side, you need to unscrew them all the way (this can be a little tricky bc there is a piece of plastic holding them in and you need to push the plastic out of the way to unscrew them all the way) you will understnad when u see the screws. After that the horn button should come right off. I dont know how to remove the rest of the steering wheel, i never had to do it.
Lo-Fi Version Time is now: September 14th, 2026 - 10:46 PM
