> lsd tranny, after market lsd r stock lsd
post Mar 12, 2009 - 3:51 AM
Dragondog
Joined May 10, '07
From Lubbock, Texas
what is better a non LSD tranny with aftermarket LSD installed or a stock tranny with LSD............basicly the gt 5sfe tranny (dont know model of that tranny sry) with aftermarket LSD installed or th e153 LSD tranny
r maybe the e153 with aftermarket LSD
This post has been edited by Dragondog: Mar 12, 2009 - 3:53 AM
feedback
feedback
If I buy or sale please leave me feedback...thanks
cheap, quick, reliable, pick two
I treat my 6gc better then my own woman
post Mar 12, 2009 - 4:58 AM
QUOTE (Dragondog @ Mar 12, 2009 - 3:51 AM) *
e153 w/lsd FTW every time.
you can install the MKIII mr2 factory option lsd into the s54 (GT) tranny, but your still stuck with the super short gearing.
post Mar 12, 2009 - 5:14 PM
reko
Joined Apr 17, '07
From Montreal, QC, Canada
So LSD is an option on e-153?
Is there a way to know if the MR2 has the LSD ? Like, does all SW20 have LSD?
post Mar 12, 2009 - 5:18 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
post Mar 12, 2009 - 9:38 PM
lsd was an option on 93+ mr2T's.
it mates to "s" series engines, griffy.
post Mar 13, 2009 - 8:15 AM
reko
Joined Apr 17, '07
QUOTE (presure2 @ Mar 12, 2009 - 10:38 PM) *
I never saw a tranny with LSD. Any hints on how it looks like?
post Mar 13, 2009 - 4:18 PM
_Jim_
Joined Sep 22, '08
From Bergenfield
Over 80% of GEN3 Mr2's came with E153 LSD. There is a very simple way to tell if the trans has LSD if it is off the car, or the axles are out of it......there will be a "bar" going across the back of where the axles sides into the tranny. I need to pick up batteries today for the camera......so I will post pics of exactly what I am talking about later. (I am running an E153 with LSD from a GEN3 Mr2)
330whp 309ft/lbs @ 21 PSI
post Mar 13, 2009 - 4:42 PM
GriffGirl
Joined Feb 7, '07
QUOTE (presure2 @ Mar 12, 2009 - 7:38 PM) *
So here's my next question— these came optional on MR2Ts (OPTIONAL!? Uh, yeah, that's a no-brainer if you ask me!), okay, which means that they would need to be converted to FWD for Celi transplant use.
I did a little research and also found that these came in the v6 Camry starting in 1992 as well and purportedly can mate up to a 1mzfe - is that because it's a FWD tranny? Did they come w/LSD? I realize that motor is a completely different motor than my puny little F engine, but I'm just trying to understand how this all works. If a 3.0 1mzfe Camry came w/LSD, then it would stand to reason that that would be the tranny to be searching for, not an MR2 tranny necessarily.
post Mar 13, 2009 - 5:02 PM
the e153 from the camrys and solaras are non LSD, and are FWD.
just to add to what jim said earlier, the factory LSD's from e153 have the bar, non lsd e153 does not, however, the s54 trannys have the same type of bar, but are non lsd.
post Mar 13, 2009 - 5:17 PM
Dragondog
Joined May 10, '07
From Lubbock, Texas
QUOTE (presure2 @ Mar 12, 2009 - 10:58 AM) *
ok ic so the e153 has longer gears thats a plus..where will it redline at.....r would that depend on the motor
This post has been edited by Dragondog: Mar 13, 2009 - 5:19 PM
feedback
feedback
post Mar 17, 2009 - 4:18 AM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
like presure said they did not have the option for LSD on camry e153... but you can insert it smile.gif smile.gif "TRANSMISSION:
99 Camry V6 5spd transmission w/ 95 JDM MR2 Limited Slip Differential"
Breaking Axles...
post Mar 17, 2009 - 6:41 PM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
what can be used for beams transmission swap with gt axles? can this be used? http://www.horsepowerfreaks.com/performanc...n/Differentials
and i was doing radiator flush and fill the other day. this vid just shows how you can test if you have lsd or not... or atleast i think it does, some people said it
doesn't.
people say it caused fwd to understeer more? that true??? understeer is caused when you touch gas quickly through a sharp turn. (hmm feel like im repeating myself here. i think i said this in another lsd post) so from my understanding from horsepowerfreaks trd lsd discription. if not accelerating hard. you will have tendency to understeer.
This post has been edited by BonzaiCelica: Mar 17, 2009 - 7:55 PM
post Mar 18, 2009 - 12:41 AM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
not true at all... not even close... the e153 is not a clutch type lsd... it will only engage under load... that video is 100% false... that car could or could not have lsd... jacking it up and spinning the wheels is NOT a way to find out for an e153 with stock lsd
Breaking Axles...
post Mar 18, 2009 - 12:59 AM
Rusty
Joined Nov 5, '07
From New Zealand
(kind of dangerous) just jacking up one wheel or having one wheel off the ground somehow safely, if no lsd the free wheel would spin
sorry not putting much thought into it
post Mar 18, 2009 - 4:51 AM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
Get your mate to do a short burn out and stand about 20 meters infront to see if both wheels smoke up.
lsd doesnt create understeer, its designed to help eliminate the natural tendency of a front engine front drive car to understeer. the visible effect with lsd is when using a heavy foot around corners, the car accelerates towards where the wheels are pointed rather than towards where the car itself is pointed.
Mike W
269awhp / 273ft-lbs
post Mar 18, 2009 - 6:56 AM
Dragondog
Joined May 10, '07
From Lubbock, Texas
on my 5s tranny i can noticably see that it has been open and tamperd with.....i did a burn out on it to check if it has had a lsd installed b4 i bought it....i burn out dual tracks equal melted the tires on both sides and left equal burn out marks........???
feedback
feedback
post Mar 18, 2009 - 7:02 AM
QUOTE (Dragondog @ Mar 18, 2009 - 6:56 AM) *
that means nothing, my car also leave 2 tire marks, no LSD
http://www.youtube.com/watch?v=zFRwgBipDZc
post Mar 18, 2009 - 4:31 PM
_Jim_
Joined Sep 22, '08
From Bergenfield
I am RUNNING an E153 with LSD in my setup, BUT have had the experience of running an E153 NON-LSD on my old setup to compare to.....and I can tell you there are ZERO differences between the E153 LSD and E153 NON-LSD in the way the care feels under NORMAL driving conditions. Normal meaning just out driving, not really pushing the car.
When taking a turn and accelerating threw it WITHOUT putting any real load on the motor.....the E153 LSD feels/acts NO DIFFERENT than the same car with a NON-LSD E153.....As a matter a fact.....it feels/acts NO DIFFERENTLY than a NON-LSD S54.
Now, when you are really pushing the car is when you feel the LSD. When pushing the car in a straight line.....the car is smooth as glass, and there is ZERO torque steer, unlike NON-LSD transmissions where you really need to hold/fight the wheel when accelerating hard.
As for turning....well a NON-LSD will be able to turn "sharper" than a LSD when really pushing the car threw a turn. If I push the car threw a turn, I can feel the car want to "push/straighten out" in the opposite direction of the turn. This is because both tires are doing the same speed, when the inside wheel "should/want" to spin at a slower rate.
To clear that up.....if I am really pushing the car hard threw a sharp right hand turn, the cars wants to "push/straighten out" to the left......and opposite goes for a left hand turn.
This is not uncontrollable by any means, just takes a bit of getting used to.
post Mar 18, 2009 - 6:35 PM
Dragondog
Joined May 10, '07
From Lubbock, Texas
ok ic...what bout driving in wet/icey conditions does the lsd help at all....?
feedback
feedback
post Mar 19, 2009 - 1:55 AM
Rusty
Joined Nov 5, '07
From New Zealand
cant you use a s54 and a s53 to make a longer gear ratio?
Lo-Fi Version Time is now: August 4th, 2026 - 9:16 AM
